Old 03-09-2013, 04:18 PM
Dr.Acula Dr.Acula is offline
Default 1969 Camaro Front & Rear Wheel Fitment
Hello Lateral-G!
I have one question for all you knowledgeable 1st gen Camaro gear heads. Would it be possible to fit a 20x10 5.5bs rim on the rear of a non tubbed 1969 Camaro with a Ford 9? If so, which what modifications would need to be done? Also what tire would I be able to fit back there with this fitment?
Thanks!!
Old 03-10-2013, 07:23 PM
meanchicken meanchicken is offline
Maybe this will help.
http://www.camaroperformers.com/cama...o/viewall.html
87 Grand National:Czarnota stroker roller V6;ported heads/intake;3200 billet stall 10";built 200R4;PTE 6265 DBB;3" THDP;TT Alky chip;60# inj;HD Adj WG actuator;AFPR;160* stat;Alkycontrol;TRC Big Mouth;PTE FMIC;Hooker cat back...and a boost gauge. 11.14@122 on 24lbs
4-sale 68 SS Camaro:ZZ502;TKO-600;Moser 12-bolt;Global West control arms;QA1 coil overs;SSBC power disks;quick ratio steering;Hotchkis sway bar;solid body mounts;Be Cool rad;Pertronix ign;other stuff. 4-sale
Old 03-10-2013, 07:26 PM
http://www.chevyhiperformance.com/te...s/viewall.html
