Old 03-12-2013, 12:54 PM
RBuhr69's Avatar
RBuhr69 RBuhr69 is offline
Default Water Thermostat / Fan Sender
While I have the radiator out of my car for some repairs (yes brand new AFCO rad already leaking, arr!!!). I have been lurking around the interent reading up on where is the most desired place for your temp sensors for the thermostat and fan sensor to be located. I wont use the word "BEST" as this is opinion based answer for the most part.....
SBC not LS...Currently i have the water temp sensor on driver side near thermostat housing and the fan sensor in the head. I have done a lot of reading and yes everyone has different opinions they should be opposite what i described and some agreed. Some think they both should be in a spacer under the water neck, some think water temp in the head, fan sensor in the intake, etc...
Just curious what people think on this site in particular as there are a lot of builders (business/home) on this site and can offer some advice how they would place them before I button it all back up...
thanks.....
Old 03-12-2013, 03:56 PM
468Camaro's Avatar
468Camaro 468Camaro is offline
Water temp in the head.. Air bubbles n steam pockets will throw the readings off.when your temp sensors up top. and its the cylinder temp thats important
Bowtie Nutt 68 Camaro Pro-Street 2x3 Ladder bar -backhalf 32x14 Dana 60 5.38, 406" 12-1. .Chet Herbert Billet Roller .645" 106' .Brodix Trk1, 830" Annular,Victor.glide-brake.. Needs Real windows.. 1989 Vette Z-51 357" 4bolt Forged, Dart IIS,Comp cam..Billet Specialties, 86" Iroc-z 468-400 ,2003 Roadstar 102" ..
