Old 03-23-2013, 10:17 AM
RdHuggr68 RdHuggr68 is offline
Default LED lights
I am trying to find some good websites for 12 volt LED's. Sieg gave me Waytek but the smallest hole for the lamp is 5/16th which is kind of big for my turn signals and high beam indicator. Any info would be appreciated.
Old 03-23-2013, 12:16 PM
130fe 130fe is offline
Thumbs up
I used the 3 mm (same as 5/32) built in resistor type LED from Radio Shack. They were only a few bucks each. They have red, green and amber. They have a Red and Black leads and I wired them directly into the factory harness. I used green for the turn signals, amber for Check eng light and blue (purchased from Dse) for the high beams. If did it over again, use red for the high beam. The blue is blinding, be sure to position the HB indicator off to the side (just not in the center of your view). Hope this helps.
The one you will look for is one that looks like this- http://www.superbrightleds.com/morei...-12vdc-led/55/
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 03-23-2013, 01:12 PM
Thanks Chris I forgot about Radio Shack.
Kevin
Old 03-24-2013, 02:49 PM
crazycarguy22 crazycarguy22 is offline
Great place to try is Diode Dynamics (http://www.diodedynamics.com/store/), great selection and excellent customer service. I purchased LED flasher turn signals that switch from bright white running lights to amber turn signals as well as HIDs for my daily driver and love them.
Old 03-24-2013, 03:18 PM
DETON8R's Avatar
DETON8R DETON8R is offline
A few links, sorry for the disorganization and cryptic notes. I just keep a running list of URL's and notes as I find various web sites.
http://www.carid.com/chevy-camaro-xenon-hid/
HID, Xeon and High Output kits
http://shiny-hiney.com/camchev.html
LED lights and accessories, kits
http://www.rodworx.com/products.php?scatid=45
LED tail light assembly/LED parts
http://www.uatparts.com/
Tons of LED lights and accessories for Commercial Vehicles
http://www.watsons-streetworks.com/leds_taillights.html
various LED lights
http://www.lambertenterprises.com/
various LED’s on boards, in bezzles
http://www.cool-leds.com/
Tech Nostalgia, light inserts
http://www.noveltylights.com/Custom-...ight-Kits.html
12 volt lights in rope
http://www.led-switch.com/12%20volt%20LED.htm
LED lights – bulk, bag of 5 @1.40 each
http://www.blackhawkledlights.com/
http://www.sailorsams.com/
12-volt-led-lights marine LED lights and other accessories
http://www.ledlight.com/flexible-led-light.aspx
various led lights and bulbs for home and auto, resistors
DETONATOR - 69 Camaro RS
LS1 - T56 - Chris Alston Frame - 2" drop
G-Link Rear - 4.20 gears in 9" - Mini Tubs
Old 03-24-2013, 05:02 PM
various LED lights
Thanks for all the info, your are going to mske me work for these aren't you
Old 03-24-2013, 05:27 PM
Ron in SoCal's Avatar
Sylvania makes replacement LED bulbs for our cars I'm told.
Ron in SoCal
69 Camaro in progress
Old 03-24-2013, 07:06 PM
DETON8R's Avatar
Nothing in this life ever comes easy. Especially when putting together a custom vehicle that is unique.
This reminds me of something I see all the time whenever I go over to the machine shop. The main door to the machine shop at work has a sign on it with words to live by in this endeavor.
We do things
  • CHEAP
  • EASY
  • FAST
You only get to pick two of the three!!
