Old 03-24-2013, 01:48 PM
Cole Cole is offline
Banned
Default Ridetech subframe?
Any word if they plan to produce one. Sure would seal the deal on a complete package?
Thoughts?
Old 03-24-2013, 03:05 PM
coolwelder62's Avatar
Thoughts?
When Bret and I talked.He said he did not want to get in the sub frame market.
Old 03-24-2013, 08:24 PM
Banned
Okay, I have there complete kit and would like to add a subframe down the road using there parts.
Does your subframe incorp all there parts, Scott?
Old 03-24-2013, 09:00 PM
My sub frames use GM C-6 componet's.Ride Tech only Coil over's,AGR,or rebuilt Rack & pinion's.Find a good str. OEM subframe,sand blast it,seam weld it,Rework the upper A-arm mount. Bolt on the great Ridetech componet's and win some AutoX's.
Old 03-25-2013, 08:52 AM
Blake Foster's Avatar
IT all works with the Speedtech Sub Frame.
Just Sayin.
Blake Foster
www.speedtechperformance.com
Old 03-25-2013, 04:01 PM
Just Sayin.
Sorry Blake I forgot your frame use's Stock camaro componet's.
Old 03-25-2013, 06:46 PM
214Chevy's Avatar
214Chevy 214Chevy is offline
To the OP...here you go. Couldn't be better timing and such a good deal too. https://lateral-g.net/forums/showthread.php4?t=40556
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 09-11-2014, 02:26 PM
grendel grendel is offline
Just Sayin.
It does? Did this change since you last posted this info?
Old 09-11-2014, 06:44 PM
Rod P's Avatar
Rod P Rod P is offline
Just Sayin.
????WHAT???? I did not know that!! I will PM you later Blake.
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
Old 09-12-2014, 09:24 AM
paulk68 paulk68 is offline
Just Sayin.
Confused by this, when I called I was told it was not really built for other brands including ridetech
