Old 03-25-2013, 05:39 AM
paulk68 paulk68 is offline
Default Carbed LS376/515 HP
Hey Guys, I am considering this motor for my 1968 camaro. Trying to see if anyone has run this and what there thoughts are. Also what is involved in swapping this into a 68 camaro? From what i have been reading adding the FI adds some extra steps but what about the carbed version. Thank you
Paul
Old 03-25-2013, 02:26 PM
Paul
Super simple swap - and all parts are readily available.... You'll have to add an electric fuel pump... LS motors don't have fuel pumps. And if you want to run coil on plug then you need a controller.... Edelbrock has a complete kit for you already set up.
You'd LOVE the carbed version of this motor.... although it's really built to be blown... and is a bit low on the compression side of things - it would work perfectly with todays crappy pump gas.
Old 03-25-2013, 06:24 PM
Is this motor supercharger Built? I am looikng at the 480 HP version against the LSA..
Old 03-25-2013, 09:13 PM
When we were deciding and ultimately ordered the LSX 376 for the '62 Impala --- I wanted the LSX 454 --- but the compression on the 376 is 9.0 vs the 11.0 of the 454 ---- and even GM Performance "advertises" the 376 as being built for supercharged or turbo'd.
Mine had a TVS 2300 blower added to it...
I have the 480hp LS3 in my '33 Ford being built at Brizio's.
Plenty of motor for a little '33 highboy!
http://www.roybriziostreetrods.com/p...weld/index.htm
Old 03-25-2013, 11:18 PM
Sieg's Avatar
Sieg Sieg is offline
This Chevrolet Performance LS 376/515 hp is 10.7:1 comp:
http://www.jegs.com/i/GM+Performance...Fc5_QgodkUkAEw
Old 03-26-2013, 02:26 AM
Yeah that is the one i am lookingf at. Looks like a nice motor what do you think?
Old 03-26-2013, 06:10 AM
Sieg's Avatar
Yeah that is the one I am looking at. Looks like a nice motor what do you think?
Personally I'd love to have that in my car..............and I'd run the exhaust manifolds! My question would be> Do I run a Holley Ultra HP 850 or FAST EZ-EFI or a choked vac secondary carb?
515 hp is a bunch for a street car and more than adequate for a good time on the track. Hobaugh's Corvette is a good example of not needing 600 hp to be competitive. All said and done the EZ-EFI is not going to cost much more than a good carb if you factor tuning time or a competent tuner, tuning components expense, etc. Same simplicity applies to the exhaust manifolds, do you need to spend $1500 on headers for extra power vs the heat, noise, and tight clearances they create?
Old 03-26-2013, 06:53 AM
It does look like a really fun engine for the street/ocassional track visit. I think for that price it actually comes with the carb if i read the directios sheet correctly
Old 03-26-2013, 07:18 AM
Sieg's Avatar
It does look like a really fun engine for the street/ocassional track visit. I think for that price it actually comes with the carb if i read the directions sheet correctly
I don't read the Jeg's listing as including a carb. Who are you considering buying it from?
I'd also review a dyno sheet to confirm the torque curve. Torque will make the biggest daily driving impression unless you spend a lot of time above 4K rpm.
Old 03-26-2013, 07:29 AM
I will call, but I found this on the instructions tab on that jegs page it also has the dyno graph. looks like around 475 for the TQ
Carburetor
GM Performance Parts Carburetor part number 19201993 is included with the LS376/515 crate engine. This is a
Holley 4160-style 770 cfm carburetor and features dual feed, center hung float bowls, vacuum secondaries and
automatic electric choke. Instructions and specifications are included in the carburetor package
