Old 03-30-2013, 06:03 PM
heynow14 heynow14 is offline
Default T-56 Magnum noise at speed
Hey us-
Looking for some help from those who know the T-56. Mine has only about 250 miles. ZZ4 350 crate motor in early Camaro.
On freeway above 60 if I push clutch in, I get a noise that sounds like something 'dragging'..not a grinding...but still not right. It seems to do it with clutch not pushed in (off throttle) too but it's less obvious. Under power it sounds fine although things are louder so who knows. So, with clutch in or coasting in gear, I get the sound. Tremec suggested switching to synthetic fluid. It made no difference with the noise.
Around town, under say 50mph, it shifts and drives great...this is bugging me and I want to be sure I'm not making it worse by driving it.
Thoughts?
Thx,
Nick
Old 03-30-2013, 07:07 PM
Sieg's Avatar
Sieg Sieg is offline
What bellhousing, clutch, flywheel, and throwout bearing are you using?
Did you check the runout in the housing?
How much free play between the pressure plate fingers and throwout bearing?
Pilot bearing greased?
Old 03-30-2013, 07:37 PM
Thx Sieg,
McLeod clutch and pp
Bell was existing from 4-spd in car before my time
I had a speed shop install and thy did runout/alignment measures. Said it all checked out in spec.
ZZ4 flywheel resurfaced
TO bearing unknown.
This is wacky since it shifts/drives great at lower speeds but I wanted OD to get on the freeway...
Thanks for your time!
Old 03-30-2013, 10:42 PM
If it gets worse pushing in the clutch, I'd lean towards the throw out bearing.
Old 03-30-2013, 11:37 PM
Sieg's Avatar
Originally Posted by heynow14 View Post
Thx Sieg,
TO bearing unknown.
So you used an adapter plate?
The shop said it was OK...............what were the specs that made it OK?
Throwout bearing clearance was?
If they can't spec it they most likely didn't check it and that could be the source of your problem....but you don't know until you check it.
Those specs need to be confirmed as part of the trouble-shooting process.
Old 03-31-2013, 08:51 AM
So, you'd say it's standard operating procedure that a shop would need to log all of these measurements? I've read that housing runout is mandatory but that was it, I thought?
My installer is already pointing the finger at the trans itself, but I highly doubt that.
Old 03-31-2013, 10:06 AM
Sieg's Avatar
I'm saying assumptions interfere with trouble shooting the cause.
All the questions come from the installation manual for a T56.
A T56 will not bolt up to a standard bellhousing. What adapter plate was used or how did the installer make the connection? A Quicktime bellhousing is one of the few that may not require runout adjustment.
If he's pointing the finger at the trans, ask him to qualify his work first. There's more defective mechanics than defective T56's.
Old 03-31-2013, 04:47 PM
The Magnum kit from American Powertrain comes with their adapter plate. Their paper work and install instructions ask for bell runout but say nothing about TO clearances. I know the installer is going to tell me to stick it so I need to know what responsibilities they have.
Would you say that TO clearance measures are something that an installer would as a default, always perform?
Old 03-31-2013, 06:01 PM
Ketzer's Avatar
Ketzer Ketzer is offline
There are a couple of youtube videos out there that detail exactly what has to be checked. You could watch and familiarize with the lingo (it's a lot of stuff to look at/verify), Help you to fight back with the knowledge of what "should" have been done. Probably gonna take a third party mechanic to look at it and verify what was done wrong.
Jeff-
Old 03-31-2013, 08:45 PM
Right on...I will check out some vids. If anyone else has some experience with T-56 with similar issue, please let me know what resolved it.
Thanks to all for your input...I was on the fence about installing myself and now I know I should have...this is ridiculous.
Nick
