Old 03-30-2013, 06:41 PM
RdHuggr68 RdHuggr68 is offline
Default shifter boot
Need to install shifter boot but I know drilling through the carpet will cause some unraveling. Any good tips out there for drilling through carpet.
Kevin
Old 03-30-2013, 09:26 PM
carbuff's Avatar
carbuff carbuff is offline
Any chance you can drill from the bottom? I doubt it, but thought I would ask.
I just did something like this last night, but my solution won't work as well for you. There is a 'punch tool' that is made to cut through material like carpet when using a hammer. I used that to create the holes, then I could put a drill bit through them to drill into the metal.
You might be able to do something similar with an awl. Try to open the holes up in the carpet as wide as you can with an awl, then you can have space for the drill bit? You could do this by lifting the carpet and pushing into the tunnel opening maybe...
Old 03-30-2013, 09:29 PM
carbuff's Avatar
A tool like this, but smaller.
http://www.techtoolsupply.com/Produc...tCode=SKY25316
The reason it won't work as well for you is you need something sturdy behind it to 'hit' against. I used a 2x4, but you may not be able to get one under the carpet...
Old 03-30-2013, 10:55 PM
RECOVERY ROOM's Avatar
Supporting Vendor
RecoveryRoomInteriors.com
Just cut a small slice first with a Xacto knife then drill hole, Easy and fast
TRACY WEAVER
www.recoveryroominteriors.com
Old 03-31-2013, 09:25 PM
Dunatics's Avatar
Dunatics Dunatics is offline
When drilling through carpet, I like to use a very hot soldering iron first. The soldering iron will melt the carpet so it doesn't unravel and makes a clean hole.
