Old 03-30-2013, 10:35 PM
Ketzer's Avatar
Ketzer Ketzer is offline
Default BBC gurus, oil in the radiator...
It's a fresh build with less than a dozen miles. No water in the pan but it's definately pushing oil into the cooling system somewhere and showing up in the radiator.
There is not an oil cooler in the rad.
I'm guessing one of the usual suspects, head gasket, galley plug didn't seal, or worst case a hairline crack...
Any dianostic tips before I tear into it? Thoughts on running some dye through to help highlight the culprit?
Jeff-
Old 03-30-2013, 10:38 PM
Was it a new radiator? Did you flush it out prior to installation?
Old 03-30-2013, 10:53 PM
Ron in SoCal's Avatar
Only a dozen miles, no foaming?
Ron in SoCal
69 Camaro in progress
Old 03-31-2013, 04:50 AM
Ketzer's Avatar
It is a new radiator. I didn't do the build, bought it already done so I'm not sure on the flush? I did drain it (as much as you can without pulling the t-stat) and ran some scalding hot water through the rad until it was clear and re-filled it fresh. Ran it for about 20 mins and quite a bit of oil showed back up... but oil doesn't seem to be down on the dipstick enough to account for all the oil ?? (It was still warm and hadnt completely all drained back to pan but was still very close to full mark)
Only a wee little bit foamy on top when running, not stout beer foamy....
I was only able to look at a few things last night before I ran out of time and won't be able to touch it again until Monday. It's tough to put the tools down and walk away when this is happening. Now my brain is going crazy and I can't put my hands on it....
Jeff-
Old 03-31-2013, 07:09 AM
RBuhr69's Avatar
RBuhr69 RBuhr69 is offline
I would definetly be calling the builder Monday morning and asking if everything was checked for cracks....If they say yes, then I would remove thermostat, bolt thermostat housing back up and find a longer lower radiator hose and have the water pull from a 5 gallon bucket (0bviosuly filling bucket as it runs), leave the hose off the outlet on the radiator and just let it flush all the way through. This way you can flush the entire system and then bolt it all back up and see if any oil returns.
Just a thought..
Otherwise, rut row scooby....Pulling motor or at minimum take top end apart.
Old 03-31-2013, 08:18 AM
Is this an automatic car with a trans cooler incorporated into the radiator? Are you certain it's oil? New GM motors come with a sealant "tablet" installed in the motor so the first time you run 'em that tablet dissolves...
Is there any WHITE "smoke" when you fire it up?? That indicates moisture in the cylinders (steam).
I'd run a leak down test on it --- if it's a block issue or gasket issue a leak down would push bubbles into the radiator... leave the radiator cap off and if the gauge is leaking down - then start looking into the radiator for tell-tale signs etc.
If you don't have a leak down gauge set -- some places rent them... Or let me know if you can't find one and I'll send you mine.
The other thing you can do and this would be the fastest cheapest easiest --- run a pressure test on the cooling system -- if it doesn't hold pressure you know you have an issue right away. That would be what I'd do first.
I have a Test kit made by Stant --- if you can't find one locally --- or find someone old skool enough around you with one I could send that as well.
Old 03-31-2013, 08:28 AM
Ketzer's Avatar
Just a thought..
I bought the whole car already running/driving, the seller didn't build the engine so getting back to the builder for questions might be difficult. Buying hot rods is always a gamble. I'm pretty sure the seller had no idea it had a problem.
My number one plan for tomorrow is to go back and do a proper flush, clean, de-grease of the cooling system just like you suggested. I hoped the half-azzed drain I did yesterday would show me something, it showed me how to waste time and fresh anti-freeze without telling me squat.
I double-checked this morning before I left, after everything cooled down, the dipstick still shows full on oil. It does not seem to be losing any noticable amount of oil and yet a paper towel dipped into the rad looks like this...
I'm also going to try and score some dye for the oil to be sure it is coming in fresh and not residual.
I really appreciate any comments or tips.
Jeff-
