Old 04-01-2013, 07:33 PM
RBuhr69's Avatar
RBuhr69 RBuhr69 is offline
Default AM Short Sweep Fuel gauge
Question, I have the AM short sweep electric gauge for the fuel gauge. There are three wires for the factory gauge but there is only one slot on the AM gauge for the sendor signal.
So my questions is can i use the factory wiring in some sort of manner, or is there a sendor unit I need to purchase? I will be installing it all this Friday and want to be prepared if I should have ordered a sender or am I able to just use existing wiring...
Old 04-02-2013, 05:29 AM
drc270 drc270 is offline
I am not sure about factory gauges but I would imagine those 3 wires
are power, ground and sender.
Old 04-02-2013, 08:09 AM
130fe 130fe is offline
Thumbs up
Yeah, just like DRC says there are 3 inputs on the AM guage (ign, ground, signal). You can use the the tan wire on the factory dash cluster connection for your signal on the gauge. You can use your existing tank sendor (assuming it is the factory or aftermarket one), you just have make sure the gauge and sender are the same ohms range (factory camaro sender is 0-90 ohm).
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 04-02-2013, 11:15 AM
RBuhr69's Avatar
thanks......Just wanted to be prepared and not find out I needed a different sendor as I ordered the gauge for factory ohms...
Old 04-07-2013, 05:38 PM
RBuhr69's Avatar
Thanks for the help, Tan wire worked out perfect.......All gauges are in!
