Old 04-08-2013, 07:53 PM
coolclassiccars's Avatar
coolclassiccars coolclassiccars is offline
Default 2010 camaro transmission yoke
i was wondering about the fixed yoke in the 10 camaro transmission.(i think its a tr6060 )anyone know how hard it is to change it or just get a different trans did several searchs with no luck.thanks for any help.shawn
Old 04-09-2013, 10:27 AM
spooty spooty is offline
Are you looking to install a different flange or converting to a slip-yoke design? The slip yoke conversion would only have a small section of spline to engage and there is no bushing inside to engage...not good for high power applications. What are you wanting to do with this?
Old 04-09-2013, 06:54 PM
renegade6 renegade6 is offline
There is a kit you can buy to convert the fixed yoke to a slip yoke for the 6L transmissions. I believe it had a rear clutch drum, yoke and tailshaft housing.
63 Biscayne
Schwartz Performance Chassis
Build thread: https://lateral-g.net/forums/showthread.php4?t=37302
Old 04-10-2013, 05:17 AM
thanks for the replys a friend was looking to buy a 6.0l gto motor, trans combo.the rear yoke is a none slip type.i didn't know if anyone has experienced this problem.
