Old 04-14-2013, 06:14 AM
Default HARNESS for LSA..
Hello, ripped out my dash and did some celan up work on both sides of the firewall. I want to take advantage of the easy access and do all of the wiring, AC, ducting before i weld the dash in.
I was looking at the GMPP http://store.chevroletperformance.co...-19201861--%3E
but was wondering if their might be a better route? Also I may go LSA can I purchase a harness that will work on LS3 or LSA and pick up the controler later?
Old 04-14-2013, 09:17 AM
INTMD8's Avatar
INTMD8 INTMD8 is offline
My personal preference for harnesses is Speartech. Always excellent work and they will build the harness exactly how you want it.
(distance from engine to ECU), do you want a/c request/pressure sensors, auto or manual trans.
The Speartech harness is lays out nicer in the engine compartment (IMO) and also the fuse box included with the GMPP harness is on the large side so harder to manage a clean install.
69 Charger. 438ci Gen2 hemi. Flex fuel. Holley HP efi. 650rwhp @7250 510rwtq @5700. 95 F355. 96 Carrera 4S. 59 Cadillac series 62 convertible.
Old 04-14-2013, 09:25 AM
rjsjea's Avatar
rjsjea rjsjea is offline
I bought one from BP automotive, happy with how it turned out. Price was great, compared to others
RobS
71 Demon, AlterK - 4 link GenIII hemi conversion
66 Rambler Classic Wagon, LS conversion -Scott's IFS/4bar-bagged
Old 05-01-2013, 01:00 AM
Bsinclair Bsinclair is offline
I used modern vintage systems and I am very happy. Everything is custom built to your specification. If you need contact info let me kbow..
Old 05-06-2013, 11:14 PM
69convertible 69convertible is offline
I am going to run my battery in the trunk, 69 camaro convertible with LS3 and TKO600. Whos harness accomadates a battery in the trunk?
Old 05-09-2013, 05:52 PM
kwhizz's Avatar
kwhizz kwhizz is offline
I second Speartech.......John is the Best!!!
Old 05-11-2013, 09:25 AM
got contact info? let voice mail and email... crickets...
Old 05-11-2013, 09:26 AM
Yes please... PM me if you can
Old 05-28-2013, 08:19 PM
MisterD MisterD is offline
Also check Howell and PSI. I had a local GM EFI engineer/car builder suggest Howell for a clean instal. I am still shopping also.
My Build Thread:
http://ls1tech.com/forums/conversion...ly-button.html
Old 05-28-2013, 09:36 PM
64pontiac 64pontiac is offline
LSA harness and ls3 are different especially if using a gm controller. Just letting you know. If you go aftermarket like MAST you may be able to swing it both ways
Tyler
HPI Customs
Manitoba, Canada
www.hpicustoms.com
