Old 04-23-2013, 09:26 PM
usa-69z usa-69z is offline
Default C Clip Eliminator Identify
Guys ive got a eaton posi (moser) 12 bolt rear with the big ford torino bearings/ends. It currently has drum brakes.
What im trying to work out is does it have c clips or eliminators fitted? I have removed the locking bolt and rod to move my axles in to get to c clips but axles dont move at all. They dont . The flange has the backing plate fitted with another plate over the top about 4mm thick. Is this an eliminator plate? it is all fitted from moser in 2009.
thanx, Gav
downunder
69 CAMARO - RIGHT HAND DRIVE AUSSIE MODEL.
383 SBC 8 STACK INJECTED EFI.
RIDETECH FOUR LINK REAR - DSE MINI TUBS .
SPEEDTECH FRONT A ARMS & COILOVERS.
MOSER 3.7 REAR- 6 SPEED T56 TREMEC.
FIKSE RIMS ETC ETC..
Old 04-23-2013, 10:34 PM
intocarss's Avatar
If you're running Ford ends on the rear end housing, then the axle bearings are pressed onto the axles and the outer plates that bolt the axles to the housing is what holds the axles in.... NO C clips
Undo the four bolts on each side holding the axle outer bearing plates and remove axles
The ford ends eliminate GM style C clips
Old 04-23-2013, 10:51 PM
thankyou sir !
Old 04-23-2013, 11:04 PM
Sieg's Avatar
Sieg Sieg is offline
This may answer your question Gav: http://www.moserengineering.com/comp...figurator.html
Scroll down on the options, bolt in prefered, C-clips $157.50 add.
JerDawgy beat me.........again.
Old 04-24-2013, 08:42 AM
yeah thanx guys,, once i had a closer look i worked it out.. ford ends on it means for 4 bolts to remove axles..
Gav
Old 04-24-2013, 02:27 PM
intocarss's Avatar
