Old 04-25-2013, 09:49 PM
72Z/28's Avatar
72Z/28 72Z/28 is offline
Default 68 camaro windshield glass
Hello guys
Just wondering if anybody can advise me where to get the USA Made windshield glass. I am trying to avoid getting the imported one that might have some fitment issues
Your input guys will be apprciated
72 Camaro RS:SOLD
68 Camaro:
LS6 Engine,Tremec TKO 600,5 Speed
Complete Speedtech Subframe Kit,Speedtech Torque Arm, 9" Rearend from Strange, Wilwood Brakes, Minitubbed, Hotchkis Subframe Connectors, FIKSE FM5s
Old 04-26-2013, 08:30 AM
Lenie's Avatar
Lenie Lenie is offline
Got mine from Mike of Muscle Rodz, sponsor on here. Perfect fit.
http://www.musclerodzstore.com/
Lenie
Old 04-26-2013, 11:46 PM
72Z/28's Avatar
Was it manufactured in the USA or imported? any idea please
72 Camaro RS:SOLD
68 Camaro:
Old 04-27-2013, 05:14 AM
Sparks67's Avatar
Sparks67 Sparks67 is offline
His supplier is in Canada, so it would be imported. The question is does Mike of Muscle Rodz supplier import the glass from China or it is made in Canada?
The only USA made supplier is called Pilkington. Their warehouse location is in Columbus, Ohio.
http://www.pilkington.com/north-amer...s/default1.htm
You are limited to only clear or green tint.
Jeff
Old 04-27-2013, 04:20 PM
Musclerodz's Avatar
No smoke glass is made in the USA. The issue is not that it is imported, it is if the company having it made cares enough to make it right. We have had zero issues with windshields. Unless your looking for smoke I suggest buying from the installer. They are happier and if there is a problem, easier to fix a problem. Most installers around here use PPG.
Mike Redpath
Musclerodz & Customz
facebook page
Old 04-27-2013, 08:49 PM
Sparks67's Avatar
Original poster wanted windshield glass, but never mentioned the tint. All the PPG warehouses closed in Ohio. PPG is now PGW, but a few people have reported PPG or PGW optics was warped, and the glass had to be replaced with Pilkington. I have talked to Matt at Sled Alley, and Mayhem uses Pilkington glass. Well, I just got back from Sled Alley today.
Jeff
Old 04-28-2013, 02:56 AM
72Z/28's Avatar
Thanks for your post Mike, I want a no smoke windshield glass for 68 camaro coupe. I am going to send you a PM with the shipping address.
72 Camaro RS:SOLD
68 Camaro:
Old 04-28-2013, 02:58 AM
72Z/28's Avatar
Jeff
Thanks Jeff for your input, I will try to get it from Musclerodz since they have had no issues with their windshields
72 Camaro RS:SOLD
68 Camaro:
Old 04-28-2013, 11:53 AM
Sparks67's Avatar
Here is the Original glass according to http://www.camaros.org/glass.shtml
Background
The primary first-generation Camaro glass supplier to the Camaro assembly plants (both now closed) in Norwood, Ohio and Van Nuys, California was Libbey Owens Ford (LOF). LOF continues to do business as a division of Pilkington and has reissued their old glasses under the name Pilkington Classics. A tertiary supplier of first-generation Camaro glass was Pittsburgh Plate Glass (PPG), which also supplied equivalent glass to the Firebird assembly plant in Lordstown, Ohio. Contractual agreements theoretically allowed GM to purchase from either supplier for either GM division in the event of a shortage at the other supplier, but the only PPG glass use that CRG has verified to date in 1967-68 Camaro is occasional use in 1967 vent window glass. While there seems to have been some increase in the amount of PPG glass in '69 Camaros, especially at the Norwood Camaro assembly plant, due to the dominance of LOF glass in Camaro, this edition focuses on LOF glass. PPG marking details remain less well known to CRG, but as of the 27-Feb-2006 release are now briefly covered in the PPG marking appendix.
__________________________________________________ __________________________________________________ __________________________________________________ ______________________________________
Mike's Muscle Rodz supplier is located in Ontario, California. JRD international. http://www.classic-new.com/
The company doesn't say they make glass at all. So, I did a little research on it. Well, when a company has a warehouse in California, then it is most likely getting parts for overseas. Here is the bill of ladiing information from google.
Perhaps the link is much easier to read from Google translate.
http://translate.google.com/translat...lr:lang_1zh-CN
Bill of lading information in North America Date of arrival 2011-01-17 Bill of lading number OERT101701A00016
Importers and exporters
Name of the importer JR DISTRIBUTOR INTERNATIONAL INC., Names of the exporters YUAN CHANG GLASS CO., LTD. Importers address 1229 W. STATE ST, ONTARIO, CA Exporters Address NO.100, LANE 800, CHUNG SHAN SOUTH 91762. USA RD., YANG MEI TOWN, TAOYUAN HSIEN,
TAIWAN, ROC
Name JR DISTRIBUTOR INTERNATIONAL INC., Address 1229 W. STATE ST, ONTARIO, CA 91762. USA
Product Information
Weight (kg) 19234.00 KG Size 56.00 CM Number 54.00 WDC Container volume 0.00 Shipping Information
Carrier
Country of origin China (Taiwan) Referred to by the carrier OERT The clearance zone
Name of the vessel OOCL NINGBO Arrived in Hong Kong Long Beach, California Voyage 63E52 FOB port Kao Hsiung, Kaohsiung Route Taoyuan, Taiwan Destination
HS Code
Office of departure
Appraisal 0.0 Mode of transport 10 Descriptions
Product Code
Product Description OOLU7759803: WINDSHIELD (LAMINATED) AND SIDE DOOR GLASS AS, SORTED Marks OOLU7759803: JR LOS ANGELES JR-1152B C / NO. :1-54 MADE IN TA, IWAN ROC
The company that makes the glass for JRD International is located in Taiwan.
Yuan Chang Glass Co. Ltd.
No.100, lane 800, chung shan s. rd.
326 Yangmei, Taoyuan Shine
Taiwan
Phone:011-886-3-4755151
Fax:011-886-3-4751729
http://yc-glass.myweb.hinet.net/index.htm
Fit? Vendors typically tell you that they have zero issues with fit, but the problem can occur after you have the glass installed. For example, a friend of mine has a 1969 Camaro Z28 and it need new back glass. So he used Auto City Classics glass, it fit the car great. The glass cracked within 6 months. The car was never driven at all, just sitting in the garage. He installed PPG glass installed in it, but it was bought from a closing PPG warehouse. There has been zero problems with fit and the glass has never cracked. Same glasser installer.
Oh AutoCity Classics uses a manufacturer out of Thailand now, but they have used several vendors from China.
Original Poster asked me a question on where to buy the glass. Well, I go to the supplier. Pilkington Classics
1-800-848-1351
Jeff
