Old 04-28-2013, 07:42 AM
j99fbody j99fbody is offline
Default Need some help selecting coil overs for rear of 1972 firebird
Im in the process of building a torque arm style rear suspension for my 1972 firebird and going to use adjustable coil overs but not sure on what lb spring and shock length would work well on the car.
Old 04-28-2013, 01:37 PM
Supporting Vendor
You want 5" of travel at the wheels. Shock stroke depends on how and where you have the shocks mounted.
Use this to figure spring rate:
http://www.ridetech.com/tech/spring-rate-calculator/
Skunk Werks
Ridetech
www.ridetech.com
Old 04-28-2013, 02:40 PM
thanks!
1972 Firebird- Turbocharged Lq4/T56, c5 front brake upgrade, ls1 rear brakes
