Old 02-14-2005, 07:21 AM
Payton King's Avatar
Default Driving Impressions: 21st Century Subframe
Hey!
Got to drive the test mule for 21st century C5 subframe and it was absolutley outstanding. Go to pro-touring to see my brief write up as I am pressed for time today to rewrite everything. I will check back from time to time to answer any questions.
Payton
Old 02-14-2005, 07:46 AM
68protouring454's Avatar
Default payton
sounds awesome, just copy what you wrote and paste here.
we need all the specs of the suspension and some pics!!!
jake
Old 02-14-2005, 08:33 AM
camcojb camcojb is offline
This is copied off his Pro Touring post:
"Hi All!
Well, I got to drive the test mule for 21st Century's C5 sub frame. It is a 68 Convertible Camaro with their design subframe connectors and C5 subframe. Basically they put the car back together and took it to the alignment shop and then I drove the car. There has been no tweaking on the car what-so-ever.
IT WAS AMAZING! The part of the expierence that I was not prepared for was the ride quality. I would have guessed it to be stiff, but not so. I would say that it rides better than a C5 vette. The steering is lightning fast. I tried to push the car but my common sense got the better of me. I am riding around in the country going down 2 lane roads where the posted speed is 35 mph and I am doing 75 mph trying to get an idea of the car at the limit and I could not even get the tires to howl. Same two lane road and I take my hand off the wheel about 65 mph and the car tracks straight and true. This is also the case over any road irregularities as well...very stable package. Easy to drive fast.
Ed called me later in the day and had gone to a local school parking lot, hooked up a "G-Tech" and proceded to rip off a .92 on about a 70 ft circle. Again this with no tuning or tweaking of any kind running normal Goodyear rubber. 245/45/17 and 275/40/17.
Needless to say, I am very excited. I took a leap of faith after speaking with Ed and Jim and I am happy that I did. When you take someone that is use to designing race cars that run 200 mph and have them design a subframe for a 1st gen car, you can bet that it has the goods to exceed any expectations that you have. I am confident with testing, tuning, some sticky tires and this subframe in on a coupe that pulling close to 1 g will be possible. I also know that there is more to a good handling car than a skid pad figure and this car has the entire package. I get to drive a lot of cool cars as I am an insurance agent and my policyholders know that I am into cars so if they get something new I get to drive it. So this rave review comes from someone that has recently driven a 360 Modena, Bentley GT, AWD twin turbo 911 and a Mallet Z06. If you have any questions, lt them fly."
Payton
Thanks for the info Payton, sounds like a very nice setup!
Old 02-14-2005, 09:22 AM
907rs's Avatar
907rs 907rs is offline
Nice write up, Payton. You've got to be the coolest insurance guy I know!
Bill
Old 02-14-2005, 09:51 AM
Default subframe
Let me guess...I am the only one you know? Ha ha
How long is the driving season in Alaska? 1.5 days? My dad lives in Clear and my Uncle lives off of Kodiak.
Thanks for posting my write up Jody! Are you going to have you car done in time for the power tour?
Old 02-14-2005, 09:55 AM
Edward Bednar Edward Bednar is offline
Default Payton's driving impression of 21st CSM subframe
Thanks for the glowing report. True specs will come after a day at the track. One of the neat things was that when we were having it aligned that our plan to allow anyone to be able to bolt the suspension on, set the eccentrics at their midpoint and set toe and then drive over for the alignment should work very well. The jig that Jim built put tolerances so close as to be off about .05 degrees on camber and only about a .5 degrees on caster from what we were shooting for. I had to comment to Jim "damn your good give yourself a pat on the back". I'll take the blame for the .5 derees on caster as I made last minute changes constantly on him. We've got alot of adjustability built in so there is alot of tuning to do yet. We'll keep you posted. Thanks Ed
Old 02-14-2005, 10:26 AM
c.schulz's Avatar
c.schulz c.schulz is offline
Payton,
You go boy.Some of the best dollars you have spent so far??I may have to make a trip to charlotte this summer.
Chris
71 RS Pro-Touring thing.....will it ever be done?? Not with out a second mortgage! SOLD
Old 02-14-2005, 10:32 AM
907rs's Avatar
Can't wait to see the proven numbers, Ed. That's something I wish more of the aftermarket would do with their products.
Payton, the weather here in Anchorage is actually pretty mild, it isn't as extreme as Clear or as volatile as Kodiak, so we get about 3 months or so of good driving weather.
By the way, I just returned from Denali National park, which is just south of Clear, and all I can say is that I feel for your dad!
Bill
Old 02-14-2005, 10:44 AM
Default subframe
yea Chris...best dollars spent so far! I know they are going to develope one for the 2nd gen as well. Better get that body done and order one up. If you come down in october we can go to a race as well.
Clear is pretty cold. In the middle of winter he can open the door and throw a glass of water in the air and it will freeze before it hits the ground. I will stay in Charlotte.
Old 02-14-2005, 11:21 AM
Default May be in Mi. for Dreamcruise
Chris we may be in Mi. for dreamcruise.Woodward was my old stomping grounds as I grew up in Royal Oak. My youngest son is determined to get up there for the event.I still have family there, my brother lives a block off Woodward, so my son has been exposed to some of the cruising going on there on Sat. nights when we've been visiting. If we can catch up with you then you can take er for a spin.Payton's right about the 2nd gen version. Shouldn't be too long. Ed
