Old 05-09-2013, 04:17 AM
ProTouring442's Avatar
Default 6L80E Output Question
We have a 6L80E out of a 2010 Camaro, going into a '59 Impala. The Impala uses a 2-piece drive shaft with a support bearing.
What output yoke can I use to easily adapt to a fairly standard drive shaft? I figure I can put a slip joint in the back half, so I don't need to replace the tail shaft.
Thoughts?
Thanks!
Bill
You ever wonder what medieval cook looked at the guts of a pig and thought, "I bet if you washed out that poop tube, you could stuff it with meat and eat it."
Old 05-09-2013, 05:28 AM
214Chevy's Avatar
214Chevy 214Chevy is offline
Thoughts?
Thanks!
Bill
Bill, I assume you have the output shaft with the 3 prongs on it if I'm not mistaken. It would be easier and cheaper to get a driveshaft made with the front end adapted with the 3 prong fitting and the tail end made for a u-joint. That's what most guys are doing. Either that, or as you said, change the tailshaft to a splined output. I have a 6L80 out of an 08 Escalade and it has the splined output shaft.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
