Old 05-27-2013, 07:28 PM
Barnburner Barnburner is offline
Default Sheetmetal floor thickness?
I am building a 74 Javelin with a complete perimeter frame. The floor is going to be built around the frame and cage.
What thickness sheetmetal is typically used for the flooring, specifically in the seating areas?
Old 05-27-2013, 08:20 PM
badmatt's Avatar
badmatt badmatt is offline
Not sure what everybody uses, ive used 16g ans 18g mild steel, but tie the seat mount into the cage.
Old 05-28-2013, 10:40 AM
That was the direction I was aiming. Seats will be incorporated into the cage. I want to run as light gauge sheet metal as I can without oil canning. I am going to bead roll where necessary. Thanks.
Old 10-18-2013, 06:12 PM
renegade6 renegade6 is offline
I just did floors on mine and I used 18 gauge. I haven't cut the crossmembers yet but, with the tunnel, it is really solid. I had lots of oil canning after the bead rolling but, once it was welded in, it went away.
63 Biscayne
Schwartz Performance Chassis
Build thread: https://lateral-g.net/forums/showthread.php4?t=37302
