Old 04-12-2006, 01:55 PM
6D9 6D9 is offline
Default Fat lip or regular lip...??
In the same given size say 18x8" are the fat lips any wider than the regular lip style wheel?? I dont see why they would be but I heard that Fatlips are actully 1" wider than the spec.
Old 04-12-2006, 03:18 PM
Sales@Dutchboys's Avatar
I personaly like the fat lip it makes the wheel look bigger.
dutchboyshotrods.com
269-823-2967
Old 04-12-2006, 04:15 PM
JasonSS's Avatar
JasonSS JasonSS is offline
A 18" Fat Lip outer will let the design be 1" larger than an 18 traditional. The design looks 1000X (design grows 1") better and deeper (no step up/optical illusion) than traditional. if the option is there, take it!
To answer your question about wheel widths. All wheels measure 1" wider, the bead seat is .5" on both sides of the wheel = 1" total. an 18x8 will measure 9" over all, Fat Lip or Traditional.
www.rushforthwheels.com
www.driverzinc.com
www.diffworks.net
Old 04-12-2006, 04:56 PM
6D9 6D9 is offline
Cool, Looks like I will be looking for some 18x10 fat lips on 275's...
Old 04-12-2006, 04:57 PM
Budnik Wheels's Avatar
Budnik Wheels Budnik Wheels is offline
I think it should be said clearly, that a 18" FatLip wheel is 1" larger in DIAMETER, because of the steps being eliminated in comparison to the std, or Traditional rim outer. The only reason it looks deeper, is because the smooth lip of the FatLip gives you the appearance of a deeper offset wheel.
Old 04-12-2006, 08:46 PM
6D9 6D9 is offline
Thanks Mr Budnik! Quick question. What bs are you recomending to folks when they want 18x10's...5.50 or 5.75??
Old 04-13-2006, 05:50 AM
fladoans fladoans is offline
That is going to depend on what type of car, front or rear wheels, I assume rear, so is the rearend stock, what kind of brakes, rolled lip? They are going to need more info.
Steve
69 Camaro
Old 04-13-2006, 08:00 AM
6D9 6D9 is offline
Its a 69 Camaro/rear wheels/Currie bolt in 9"/drum brakes(disk later)/will roll the lips if needed/3" DSE rear leafs.
Old 04-13-2006, 12:20 PM
Well, on a 69 Camaro, with a stock width rear end, an 18X10" gets to be a little wide, but it can be stuffed in there. 5.5" backspace is your better fitment, and you'll probably have to roll your outer fenders. If you are running a 275 wide tire, with stock wheel tubs though, I'd rather see a 18X9 in there, like Steve Rupp's old 69. Well, personally, I'd rather see an 18X12 and some DSE mini-tubs, but that's me.
