Old 06-03-2013, 04:35 PM
Streetking's Avatar
Streetking Streetking is offline
Default Largest wheel fitment for '70 GTO
Guys, what is the largest wheel/ tire combo I can run on a '70 GTO with fender lip trimming?
thanks
Old 06-03-2013, 07:43 PM
andrewb70's Avatar
thanks
I run 18x10.5" rear with a 294/40 tire, no rubbing at all. You can probably run a 305 tire. Back spacing is 6.25" in the rear
In the front, I am running a 18x8 wheel with 255/40 rubber, also no rubbing. However, I just ordered some wheel hoops to widen my front wheels to 9.5" wide, and will run a 275/35 tire. I expect little to no rubbing. I currently have 4.5" inch backspacing and the new hoops will make it closer to 6".
The place that it might hit first is on the sway bar. If you run a DSE or a Ridetech bar, they seem to fit tighter to the frame, so that may not be an issue.
Hope that helps.
Andrew
Old 06-03-2013, 08:33 PM
Streetking's Avatar
Hope that helps.
Andrew
Thanks Andrew, I'm picking up a GTO if everything checks out..
SW
Old 06-04-2013, 07:06 AM
andrewb70's Avatar
SW
You can always buy mine :-)
Andrew
Old 06-04-2013, 11:28 AM
Streetking's Avatar
Andrew
Lol, didn't know it was for sale
Old 06-04-2013, 12:41 PM
andrewb70's Avatar
You, of all people, should know that everything is always for sale...LOL
Seriously, if your deal falls through, contact me. PM headed your way...
Andrew
