Old 04-13-2006, 03:14 PM
6D9 6D9 is offline
Default Car does not sit level!
Hey guys I herd this was a common problem with the 67-69 F body. Mine is a 69. I have Hotchis 2" drop front springs and DSE 3" rear springs. Here is how it sits...
Measurments are from the ground to the lowest part of the fender:
Front driver- 23.25"
Front pass- 23.75"
Rear driver-25.75"
Rear pass-26.5"
The whole car sits lopsided to the driver side. I checked the body mounts and none are crushed. I also checked for frame damage and could not find any. Also the springs are all brand new. Any suggetions?? I was alos considering dropping the rear 1" more with some solid blocks. What do you guys think???
Old 04-13-2006, 04:07 PM
907rs's Avatar
907rs 907rs is offline
Did it sit lower on one side before you added new springs?
Bill
Old 04-13-2006, 05:10 PM
6D9 6D9 is offline
I had it for a very short time before I started tearing it apart. So I dont remember..
Old 04-14-2006, 04:51 PM
jannes_z-28's Avatar
Did you tighten the spring/suspensions bushings before you let it down on the ground or did you let it sit for a while before tightening them up?
Jan
Jan Suhr
Stockholm, Sweden
'69 Camaro Z/28 LS1/T56
Old 04-15-2006, 07:27 AM
6D9 6D9 is offline
I am pretty sure I let it settle down before I tightened the shackles down. I will loosen them just to double check.
