Old 06-17-2013, 09:33 PM
BRETT ANDERSON BRETT ANDERSON is offline
Smile Wilwood Disc Brake kit
They have been lying around long enough and I don't have any use for them anytime soon.
Up for sale is a used Willwood Disc brake kit. I am told it is a C5/6 kit for a Corvette with factory 17" wheels. Here is what comes in the kit that i am selling:
Fronts: Billet Superlite 6 Radial Mount Calipers
Rears: Billet Narrow Superlight 4 Calipers
Front Rotors: 12.88" x 1.25" thick with a 5 x 4.75" bolt pattern
Rear Rotors: 12.88" x 1.00" thick with a 5 x 4.75" bolt pattern with internal parking brake
1 set of mounting brackets for the front.
No brackets for the rear
And one brand new set of Wilwood pads front and rear.
The calipers were repainted black and look pretty good, but not perfect. This is the same kit that sells for $3600. I am asking $1800 obo. Brackets can be purchased to put them on nearly any car. Feel free to PM with any questions.
Thank you
Located in Port Orchard Washington
Last edited by BRETT ANDERSON; 07-16-2013 at 06:16 PM. Reason: I forgot to add the loaction
Old 06-18-2013, 01:53 PM
lsb's Avatar
lsb lsb is offline
Default brakes
Do you have a part # for these? And will you split them up? I need front set only. Thanks.
Old 06-18-2013, 05:00 PM
ADiCarlo ADiCarlo is offline
Might be interested in the rears if the price is right.
Old 06-18-2013, 07:03 PM
I have no problem splitting them up if you two want to get together and make me an offer. Otherwise I think they would be really tough to see seperately. Part numbers are 120-6115 and 120-6116. I verified with wildwood they are billet super light 6 radial mounts.
Old 07-15-2013, 12:14 PM
New Price: $1600 obo. Just don't need them, so let's get them gone. Thank you.
Old 07-15-2013, 12:33 PM
Bryce Bryce is offline
hey Brett, hows it going? Good luck with the sale.
Old 07-16-2013, 05:32 PM
67goatman455 67goatman455 is offline
just emailed tobin @ kore3 to see how well they might mate up on my 67 GTO. hopefully not a lot of parts are required.
1967 GTO, LS2 T56
WILWOOD FORGELINE RIDETECH
$10k Budget driver/ track car
Old 07-16-2013, 05:52 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Scott,
Per the forum rules you are required to add the location to the body of your add.
Thank you.
Curtis
Old 07-16-2013, 06:15 PM
Oh sorry about that. I am located in Port Orchard Washington.
Old 07-18-2013, 10:28 PM
does this come with everything for the park brake?
1967 GTO, LS2 T56
