Old 06-28-2013, 04:40 PM
Twoblackmarks...'s Avatar
Twoblackmarks... Twoblackmarks... is offline
Default Pontiac V8 accesories brackets
I have an Pontiac 400 block in a 67 Firebird, With some crappy home made belt throwing brackets.
It has an Electric waterpump now.
I need a alternator bracket and a Power steering pump bracket.
Is there some aftermarket types that is good? Or do you have to make them yourself?
Butler performance seems to have an ok alternator bracket, has anyone used this? On the passenger side. Does the radiator hose Clear it?
And an Stock PS pump bracket probably would be best option maybe, where can I buy that? Or if it is some good aftermarket that someone may know of?
I think I will later put on a regular water pump, but I would like to keep the alternator on the passenger side, it look much cleaner With one on each side, than all on one side only.
So basically, any tips?
