Old 06-28-2013, 05:20 PM
snappytravis's Avatar
Default Battery cable size?
I notice Detroit speed sells cable made by quickcar, and it is 2 awg, It seems a lot of guys when moving the battery to the trunk are using 1awg or 2/0 What is the difference in size between the awg wire and the 1/0 or 2/0.
Old 06-28-2013, 08:15 PM
RdHuggr68 RdHuggr68 is offline
Sizes go from (example #8AWG -#1AWG, small to large then the next larger size is 1/0 AWG to 2/0AWG and so on. I purchased my wire from Cable Yard and it is called Radiflex, it is awesome wire,very flexible. I ordered 1/0 but they were out and I went with 2/0 . If you are thinking about relocating your battery check out Madd Electrical.com. Great website and awesome electrical products. I bought his relocation kit and relays for headlights plus a few other things,great products and ifo on wiring your car correctly. Good Luck
Kevin
Old 06-28-2013, 08:31 PM
Originally Posted by ccracin View Post
1awg and 1/0 are the same size. You can google stranded wire ampacity chart and you will see what size you need for a given total amp load. For most applications 2awg or 2/0 will be plenty. The exception would be typically for high power stereo systems. Hope that helps.
Not to step on your toes but #1 is smaller than 1/0 , O.D. of #1 is .58 ,1/0 is .62.
Resistance of #1 is .134 and 1/0 is .106
Kevin
Old 06-28-2013, 08:50 PM
ccracin's Avatar
ccracin ccracin is offline
Kevin
No problem, I thought that was the case. I try not to answer these questions without being certain. So I did what I suggested and googled it to make sure. Turns out I read the chart wrong. I got rid of that rubbish so I don't confuse anyone!
Chad
Instagram - @cctek
68 Chevy Pickup Project
Old 06-28-2013, 10:18 PM
Thanks for the help guys,
Old 06-29-2013, 08:18 AM
Always two things in wiring to remember ---- the DISTANCE measured is TWICE the one way measurement.... since electricity makes a "round trip".
Bigger is always better than smaller....
Third thing of the two....
MORE STRANDS of wire are better -- more flexible -- and electricity travels the outside of the strands so the more surface area the better...
Old 06-29-2013, 08:09 PM
Thanks for the reply Mr Weld, Makes sense I just want to do it the right way.
