Closed Thread
Old 07-15-2013, 04:55 PM
ALLFAITH ALLFAITH is offline
Default 1969 Mustang Fastback built by Heath Elmer
My brother is selling his pro-touring Mustang. Thought there may be interest here.
1969 black mustang fastback Built by Heath Elmer www.heathelmer.com.
A 3 owner original California Black Plate (plate comes with sale) car featured in several national magazines and has won many top awards at every show it's been entered in. Car has 3,500 miles since completion. You couldn’t build a car at this level for below $100,000
The original 302 block was stroked to 347ci with a Probe Industries kit, CNC Forged rods,SRS Forged pistons, steel crank, CL77 bearings and ARP rod bolts, polished Paxton Novi 1200 supercharger (6.5 psi}, Comp Cams XE274H camshaft - 520 lift 274 duration, Comp lifters and pushrods, Harland Sharp 1.6 roller rockers, Speed Demon 750 MS, Edelbrock RPM aluminum heads, HPC coated Edelbrock RPM intake, MSD 6AL, MSD Billet distributor, MSD wires, HPC coated Tri Y headers, Powdercoated 7 Quart Canton Race pan, Ron Davis aluminum radiator, thermostaticq-lly controlled electric fan, Flowcooler aluminum waterpump roller timing chain, HPC coated timing cover, ARP fasteners thought, polished valve covers, Billet Specia1ties breathers, Ford Motorsport mini starter, K&N filter. The entire assembly was balanaced by Basko Engine Service and assembled by Joe Martin Racing. Engines, dual 2.5" mandrel exhaust with a true X pipe and Flowmaster 2 chamber mufflers.
Tremec T5z Cobra 5 speed, Kevlar clutch, HD pressure plate, new flywheel, Bellhousing and Bearings, Cable operated clutch, shortened and balanced driveshaft, slightly narrowed 9", Traclok, 3.89 gears, Moser 31 spline axles, ARP-studs front and rear.
Global West tubular upper and lower control arms, Global West strut bars, Afco single adjustable Coil overs with Eibach springs, 1.5" swaybar, polished upper plates, polished MPG strut tower braces, Flaming River rack and pinion, Baer bumpsteer kit, de-arched reverse eye ·1eafs, KYB rear shocks, Shelby Under rider traction bars, Baer Extreme + front brakes, 6 piston Monoblock calipers, 14" slotted/drilled and zinced 2 piece rotors, Baer Sport 12" slotted/drilled and zinced 2 piece rear rotors with PBR calipers, Cobra master cylinder, Baer prop valve, all ·new braided and SS brake lines.
Custom built for this car Simmons FR18 3 piece 18x8.5 fronts with 245/40/J8 Nitto 555Rs, Simmons FR 18 3 piece 18x10 rears with 305/35/18 Nitto Drag Radial 555Rs.
The entire car was disassembled, stripped and painted. Fit and Finish are spectacular. All unmolested original sheet metal.Original floor pans, torque boxes and trunk floor. Arrow straight body with Spies Hecker base/clear wet sanded to perfection. Semi flat hood, headlight buckets and tail panel much like a Boss 302, shaved ant hole, factory sport mirrors, Boss 429 hood scoop, front spoiler, all new bumpers and trim, pop open Shelby gas cap, new wire harnesses, the battery tray and tray area are perfect as are the apron tops. The car is 100% rust free pay close attention to the reflection in the pictures, beyond straight.
Recaro Speed seats, Recaro sliders, all new Seatbelts, Carpet, Dash Pad, '65 R model Tach pod w/Autometer boost and tach, new door panels, Original Fold Down rear seat w/new upholstery, new headliner, Flaming River tilt column, Budnik Split Grip steering wheel, Hurst shifter, leather boot, completely rebuilt pedal assembly, all gauges and lights work, Kenwood AM/FM CD player, Sirius Satellite radio, 2 Kenwood rear speakers and 2 in the dash, factory trunk mat, trunk mounted Optima battery, Billet battery bracket, new fuel tank, sending unit, lines and hoses, all new weather-stripping and seals, the floor and doors are lined with Dynamat sound deadener, etc.
This car is absolutely stunning and beyond fast and will give you goosebumps everytime you drive it. It needs nothing, it drives straight runs cool, stops & handles great, and can be driven everyday. It’s been in, Popular Hot Rodding, Car Craft and has many wins at Mustang Enthusiast Shows and Goodguy events. Won best in show, best in class, editor’s choice, people’s choice and best in show at the Fun Ford Weekend.
Car located in New York (Westchester).
Asking $ 60,0000.00
PM me and will get you in touch with my brother for pictures etc.
Thx
Brad
Old 08-05-2013, 07:20 AM
Still for sale.
BTT
Old 09-13-2013, 10:48 AM
The T-man The T-man is offline
need pics
Old 09-24-2013, 10:11 AM
BIG PHIL BIG PHIL is offline
Please Pm Me With Contact Info If You Still Have The Car
Old 10-03-2013, 08:34 PM
All PM responded to. Looking to move losing storage
Old 10-04-2013, 05:28 PM
Default Contact Info
Im Intersted In The Car Please Contact Pm Me With Your Contact Info
Old 10-16-2013, 06:21 AM
SOLD
Closed Thread
