Old 07-17-2013, 05:20 PM
7firebird1's Avatar
7firebird1 7firebird1 is offline
Default Best EFI harness and ECU for LS transplant.
Hello all! I am in the process of dropping a 5.3 LS engine in my 71 Firebird.
I am in search of a good plug and play setup that works good but not overpriced. I have looked at Holley and FAST and not sure which one to go with, or maybe there is another unit I should look at. Any help would be appreciated!
Old 07-18-2013, 11:21 AM
Vince@Meanstreets's Avatar
Try searching PSI?. They seem to be affordable.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 07-18-2013, 12:12 PM
Jr's Avatar
Jr Jr is offline
Factory Ecu with hp tuners has worked pretty good for a lot of people.
Old 07-18-2013, 01:31 PM
I recommend PSI, veryy happy with mine
Old 07-18-2013, 03:03 PM
PTAddict PTAddict is offline
We've had very good success with OEM ECU and harnesses from Speartech on a number of swaps.
Latest car: https://lateral-g.net/members/borduin/
EFI Tuner for: http://www.modernclassicsauto.com
Old 07-19-2013, 09:55 PM
Jr's Avatar
Jr Jr is offline
Speaking of psi...
http://secure.ultracart.com/catalog/PSI/
Looks like Charley's jackass.
Old 07-20-2013, 11:50 PM
7firebird1's Avatar
Awesome!! Thanks for the feedback!! Never heard of PSI but definitely gonna check them out and Speartech as well.
Old 07-24-2013, 05:04 AM
64duece 64duece is offline
If the engine is stock or close to stock, a factory ECU is a great option. If you want to play abit or have mods, the HP Tuners/EFILive can do the job but not nearly as easy as Holley. If you factor in the cost of SW,aftermarket harness and a WBO2...your not far off from aftermarket territory.
Dennis
Moore Racecraft
Old 07-24-2013, 02:31 PM
gnx7's Avatar
gnx7 gnx7 is offline
I run the Holley in my RX-7 and the Chevelle project is getting one also.
The harness is simple to install. I'm no computer genius and the interface is very easy to follow/use/navigate. Upload a file for your combo and then let the self tuning do the work. You will need to clean up the idle/cold start but the rest the Holley does for the most part. I will never ever have to pay a tuner $300-600 each time to tune my car when changes are needed.
I have never been on a dyno or seen a tuner with my LS7 RX-7. It runs like a raped ape. 1.5hrs worth of tuning on it so far.
Comparison:
new LS1 stock harness $700, used computer $100, tuning $500
(then retunes are more $)
or a Holley system with easy to use interface/software
new harness/Holley computer, WB02 sensor $1500 shipped online
Old 08-07-2013, 03:14 PM
7firebird1's Avatar
Sounds like Holley may be the way to go. Thanks for the input!!
