Old 04-19-2006, 07:07 AM
fjb2069's Avatar
fjb2069 fjb2069 is offline
Default rear end dimension? MINI TUBBED 69
Hoping someone can help me verify rear end dimension.
BS 5" with tires.
tire width 12.5"
Tire diameter 26.4"
With dimension between wheels set to 53.125" leaves about 0.9" of clearance between inner wheel well and tire.
My main question is if .9" is enough at ride height?
When tires are jacked to the highest position in tubs (about 2.5" of travel from desired ride height) there is about .75" of clearance between outer wheel well and tire. At ride height there is about 1.5" of clearance on outer well. Due to the shape of the outer well I am centering the tire in tubs at highest point, not ride height. comments?
Old 04-19-2006, 07:57 AM
907rs's Avatar
907rs 907rs is offline
Sounds like you have plenty of clearance to me. Everyone I've talked to recommends .5 to .75" at ride height.
Bill
Old 06-05-2006, 12:45 AM
tyoneal's Avatar
tyoneal tyoneal is offline
BS 5" with tires.
tire width 12.5"
Tire diameter 26.4"
fjb2069
What Size and type of Wheels are you sizing for?
I will be going throught this exact exercize before too long myself.
Is the width of the rear end stock size?
Thanks,
tyoneal
Old 06-05-2006, 06:12 AM
fjb2069's Avatar
Originally Posted by tyoneal
fjb2069
Thanks,
tyoneal
Boze 20x11.5 wheels. Housing width is 48" (not stock)
Old 06-05-2006, 06:46 PM
tyoneal's Avatar
fjb2069
Thanks a bunch for the information. I'm sure it will help when I have to start my calculations.
Regards,
tyoneal
