Hey Everybody!
The guys in the shop have been working hard on a bunch of new little pieces lately. I’m happy to present to you a few that will make properly installing a T-56 and 4L80E series transmissions a much simpler proposition. Click the part numbers to see each piece on
our site
First up is a piece for the ’67-69 Camaro. One of the big issues with sticking a T-56 in an early Camaro is that it just does not properly fit without modifying the trans tunnel. To get it under the stock tunnel the back of the trans ends up pointing down so far that the headers drag on the ground and your u-joint angle is totally screwed. If you cut the whole thing out and put a drag race style tunnel in the car, all of a sudden there’s no room for your feet!
Our new
5922-F10 Tunnel Cap is a solution to this issue! It replaces the top of the transmission tunnel from the firewall to the seat crossmember to provide additional clearance. It is laser cut from 18 gauge steel and has an increasing radius edge. The bottom lip is stepped so that it can slide inside the stock tunnel and give you a good surface that is easy to weld.
Cost is only $98. Or, get it through one of our vendors here on the forum.
Next up, we have
four new trans crossmembers. Each is designed to work with the Chassisworks front clip, but can be fit in a stock front frame using the appropriate adapter. Each will work with BBC, SBC, and LS series engines. They are made from 1-1/4" x.120 wall tubing and are capable of handling over 1000 hp.
The
5916-F10-05 Tremec T-56 Crossmember for ’67-’69 Camaro/Firebird and '68-'74 Nova. Because a T-56 will not fit in the stock tunnel, as mentioned above, this crossmember repositions the back of the transmission 1” lower than stock for those who don’t want to modify the tunnel. For those who are to modify the tunnel top, there is an
included spacer that goes between the T-56 and the rubber trans mount to raise it back up. Cost is $249. Use with adapter
5916-F10-11 for BBC/SBC cars with OEM clips. Use with
5916-F10-12 for LS cars with OEM clips.
Also available for the ’67-’69 Camaro and '68-'74 Nova is the
5916-F10-06 4L80/4L85E Crossmember. This crossmember will position the transmission in the tunnel with a little massaging and trimming. An easy at home job. Cost is $269. Use with adapter
Second gen F-Bodies also get some love today!
For '70-'73 you have the option of
5916-F20-05 for the T-56 ($249) and
5916-F20-06 for the 4L80/85 ($249) will both fit in the stock tunnel with a bit of ‘massaging’ and will keep the engine at the correct angle. For fitment in an OEM frame, you will need adapter kit
5916-F20-13 which works with BBC/SBC and LS engines.
T-56 Crossmember
4L80 Crossmember
Adapter
And just for fun, here’s a pic of the prototypes laying on the ground during test fitment!
