Old 08-09-2013, 01:04 PM
gnx7's Avatar
gnx7 gnx7 is offline
Default LS parts: GMPP LS3 harness, 3 cams, adj FPR.....+ more!
I'm clearing out a lot of stuff I have laying around to fund my '69 Chevelle project. The more expensive stuff is listed at the top.
Used LS3 JE SRP boost pistons 4.070" bore
p/n 279593 688549
essentially flat tops with valve reliefs
1 piston melted from bad inj, 7 are fine
includes wrist pins.... no rods
$250
Used cams: specs for 1.7" rocker
247/255 .656/663 115LSA CC 2132R/2134R HR115 T6411-07 $300
this made 595rwhp on a 440ci LS7 with TFS235 heads/FAST90/90mmTB 91 octane
243/251 .623" 114LSA CC 13022R/13023R HR 113+3 $300
used Katech billet tensioner "black color" includes pulley; however the bearing feels sloppy
This prevents the belt from flying off at higher RPMs.
$70 shipped
Instructions for install: http://ls1tech.com/forums/generation...-settings.html
Shipping to the lower 48 states only
Old 08-10-2013, 11:36 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Are all the parts "shipped"? If not, you need to list a location. Please edit your post to clear up any confusion.
Curtis
Old 08-10-2013, 11:53 PM
67goatman455 67goatman455 is offline
its says bay area, CA in his avatar section thing
1967 GTO, LS2 T56
WILWOOD FORGELINE RIDETECH
$10k Budget driver/ track car
Old 08-11-2013, 05:06 AM
Spiffav8's Avatar
Lateral-g Moderator
Scott,
This is a common misunderstanding. The reason for the rule is that often cars, parts, etc are in a different location than the seller. Also not everyone has their location listed. So to keep it simple and clear for everyone the rule was made. If people would read the stick that says "read this before posting" I wouldn't be wasting so much of my time asking people to fix their posts and might be able to read/follow a few more builds...which is what I'd rather be doing.
Curtis
Old 08-11-2013, 05:17 AM
Rick D's Avatar
Rick D Rick D is offline
Scott,
Oh come on now Curtis you know you just want to get your post count up
Sorry back to the ad!!
Rick
Old 08-12-2013, 01:32 PM
gnx7's Avatar
I live in SF and the parts are in Danville. I work in between. aka Bay Area
Only parts listed as "shipped" are inclusive of that price. Otherwise shipping is extra. Especially on an engine block.
Some people may want to insure a $2500 FAST XFi system.... but I know I'm not paying for it
LS3 block sold locally
226/236 cam sold
Old 08-22-2013, 08:54 AM
gnx7's Avatar
LS3 block buyer flaked out..... back up for sale
I can ship via Forward Air to any terminal (you pick up) for around 60cents/lb
use upper blue map: http://forwardair.com/locations/falocations.htm (if you are closer to a location in the map below it.... there are add'l costs)
Boost-A-Pump sold
226/236 cam sold
Old 08-22-2013, 03:26 PM
tazzz2_ca's Avatar
tazzz2_ca tazzz2_ca is offline
Boost-A-Pump sold
226/236 cam sold
Can you over bore a ls3 block and how much?
-73TA WarPath (Summer 2016)
-72RS Il Vagabondo
-70 Blue Formula "Project Cochise"
-70 Z shell
-70 Formula shell
-70 Formula roller
-68 Eldorado
-67 Coupe De Ville convertible
Old 08-23-2013, 08:19 AM
gnx7's Avatar
You can overbore them. It is currently at 4.070" and needs to another .005" to clean up. At that overbore it would not be recommended to run boost; however N/A is fine.
I have a local buyer I've been speaking with and it looks like he will purchase it.
Will update when I have one.
Old 08-26-2013, 12:32 PM
gnx7's Avatar
LS3 block sold
