Go Back   Lateral-g Forums > Classifieds > Wanted/WTB
Old 08-10-2013, 11:38 AM
scherp69's Avatar
scherp69 scherp69 is offline
Default Third gen Nova bolt on door hinges - drivers side only
As the title says, I need a drivers side door hinge for a third gen Nova. I need the bolt on style. I really only need the one with the spring but will buy both if you don't want to sell just one. I really want one with no play around the pins though. Here's an idea of what I mean
you can see where the metal around the main pin is worn. I'm trying to find one without the play around both pins and bushings. It doesn't matter if the bushings are worn as i plan on rebuilding them anyways. PM me if you have some. Thanks in advance.
Mike
Pro Touring 68 Acadian(Nova)
Prodigy Bar rear suspension
Wilwood 12.2" brakes
New Gen Splitters
LS3 and TKO600
