Old 08-15-2013, 05:52 PM
usa-69z usa-69z is offline
Default right stuff rear disc adjustment
Guys , i am having major dramas setting up my rear disc or emergency brake adjustment on my right stuff rear calipers..what the problem is that the arm that you must adjust before bleeding has a hex spline that you move the arm around on to get the right position. So when i turn the spline into the correct position for the e brake the arm will not go on as it is limited by the stopper at each end of the movement. I hope this makes sense..
has anyone had any experience with this???
thanx, Gav
69 CAMARO - RIGHT HAND DRIVE AUSSIE MODEL.
383 SBC 8 STACK INJECTED EFI.
RIDETECH FOUR LINK REAR - DSE MINI TUBS .
SPEEDTECH FRONT A ARMS & COILOVERS.
MOSER 3.7 REAR- 6 SPEED T56 TREMEC.
FIKSE RIMS ETC ETC..
Old 08-15-2013, 11:51 PM
Rod P's Avatar
Rod P Rod P is offline
maybe some pictures?
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
