Old 08-21-2013, 01:22 PM
jimboR831 jimboR831 is offline
Default qa1 coilovers for 67 camaro
Hey guys I'm in the process of setting up my subframe. I picked up some upper and lower tubular control arms from a swap meet for $320 for the set. My question is I want to run qa1 single adjustable coilovers and was wondering what length shock and spring i should use. The arms appear to be stock geometry. I have an ls1 I'm putting in it so was thinking 650# spring rates. Thanks for the help. Jimmie
Old 08-21-2013, 04:10 PM
Blake Foster's Avatar
Qa1 does not make a 650lb spring.
Viking does.
but I would recommend a 550lb spring.
Blake Foster
www.speedtechperformance.com
Old 08-21-2013, 09:21 PM
Thanks for the reply Blake. Do you guys carry the qa1 with the 550lb spring at speedtech? If so a link I could purchase from would be appreciated. Thank you
Old 08-21-2013, 09:25 PM
Nevermind about the link I found it over at speedtech. Thanks again
