Old 08-26-2013, 08:18 PM
WicKeD_SS's Avatar
WicKeD_SS WicKeD_SS is offline
Default Block Lightening?
has anyone done this? I thought about doing it to my 454 but didnt know the Con's on doing this. http://www.lsmeng.com/Block-Lightening.html
I would think up to 70 lbs off a bbc would be huge just dont know what would or could go wrong doing this.
-Brian
WicKeD
Old 08-26-2013, 09:16 PM
Che70velle's Avatar
I worked at a shop that built cup engines back in the mid 90's, and we were removing as much as 30 lbs from small block Chevys. I personally never witnessed any negatives, other than cost. It was triple this cost 20 years ago.
I'd ask for references, and then follow up on them, asking specific questions.
Aside from the weight loss, you end up with a super trick looking block.
Thanks Dad!!
Old 08-27-2013, 12:57 PM
intocarss's Avatar
Seen it done to quite a few blocks
Old 08-27-2013, 05:53 PM
T_Raven's Avatar
T_Raven T_Raven is offline
Supposedly IA II aluminum Pontiac blocks are barely if any lighter than a stock block, a lot stronger though. So I've wondered how much weight could be shaved off.
67, 68, 69 & 72 Firebirds, 79 TA, 89 GTA, 01 WS6, 68 Camaro, 68 Mustang, 54 GMC awd turbo, 67 GMC
Old 08-27-2013, 06:58 PM
Ron in SoCal's Avatar
^ aluminum blocks tend to move quite a bit in high hp applications, or so I was told when I looked into it. Further, most of the weight loss gains are seen in big blocks. I had this grand idea of doing it to an LSx 454 and was told I'd be lucky to see a 40 lb weight loss. Not worth it IMO, compared to just using a big bore aftermarket aluminum block like RHS (if you like going around corners)...
Ron in SoCal
69 Camaro in progress
Old 08-28-2013, 09:17 AM
This kind of stuff is "FUN" --- but is really only applicable to MAXIMUM EFFORT applications... where every ounce is counted and every half a nano of HP is required to win. For us? Take some driving lessons... it'll take WAY WAY more time off your laps/runs.... and be invaluable for years to come.
Old 08-28-2013, 10:39 AM
96z28ss's Avatar
96z28ss 96z28ss is offline
I'd wait untill Steilow does it.
1969 Camaro LS2/T56 D1SC
www.automotivedesigneng.com
Old 09-14-2013, 01:01 PM
Twoblackmarks...'s Avatar
Twoblackmarks... Twoblackmarks... is offline
Just get an windowed main webbed Oldsmobile Block He..He.. (I like Olds)
Old 09-17-2013, 12:52 PM
gnx7's Avatar
gnx7 gnx7 is offline
An alum LS engine weighs about 420lb fully dressed.
An iron BBC is around 775lbs with iron heads right?
