Old 09-03-2013, 07:15 PM
pitts12driver pitts12driver is offline
Default stupid slave cylinder question
I have an LS3 and I bought a Keisler T56 magnum kit to go with it. The slave cylinder is green and is spring loaded to the extended position. So, my question is: does it somehow retract when filled with hydraulic fluid, or does it always ride against the fingers of the clutch?
Sorry if this is incredibly basic - all the other slave cylinders I've ever used in other applications were in the closed or compact position in the normal state.
thanks
Adam
Old 09-08-2013, 07:55 PM
dontlifttoshift's Avatar
The bearing is always in contact with the clutch fingers.
Donny
