2" drop drum spindles
09-03-2013, 11:16 PM
jimboR831
So I ran into a bit of a dilema. I'm using ls1 brakes up front on my 67 camaro and for those to work I have to use a drum spindle. I want to get a 2" drop spindle but it appears no one makes drop drum spindles. Any ideas guys
jimboR831
Find all posts by jimboR831
2
09-03-2013, 11:39 PM
David Pozzi
just add a spacer to the top bolt. Many brake kits come with the spacer. It should be around .610" thick.
http://www.PozziRacing.com
David Pozzi
Find all posts by David Pozzi
3
09-04-2013, 01:53 PM
jimboR831
Ok thanks but will the disc spindles work with the drum hubs?
jimboR831
4
09-20-2013, 12:46 AM
David Pozzi
Yes it will work the same as a drum spindle.
David Pozzi
Linear Mode
Switch to Threaded Mode
12:16 AM
