Old 09-05-2013, 07:09 PM
1Bad68Cat 1Bad68Cat is offline
Default 2013 Shelby Brembo brakes
Hi. I will be installing 2013 Shelby Brembo brakes on my 67 Cougar, but need a couple of dimensions. Does anyone have the dimensions in the picture below for the s197 generation mustang? I need the bolt circle dimension (front view) and the offset from the hub (right view). Thanks in advanced.
Robert
Old 09-11-2013, 10:18 PM
Bump. Hopefully someone might have these dimensions. Trying not to purchase a spindle/hub assembly.
Old 09-23-2013, 07:51 PM
Just a little update of the bracket I came up with.
Old 09-23-2013, 10:12 PM
Revved's Avatar
Revved Revved is offline
Have you tried contacting Brembo to see if they already have a bracket for your setup?
I've done several Baer/Shelby setups on 67 Mustangs and your bracket looks awfully familiar.... really just going to be a few .001 here and there depending on the caliper mounting. Let me know if you need any measurements against parts I have sitting here.
-Sean
Comp Performance Group
Business Development Manager
1970 Chevelle I built years back as a Lat-G Feature https://lateral-g.net/forums/showthread.php4?t=43116
Old 09-25-2013, 08:21 AM
I have not contacted brembo, but when I had looked at there website, they did not list any disc brake kits for fords older than 1994. I also didn't think they would offer a bracket to bolt the Shelby 6 pot calipers to the wilwood pro spindle I am using since there are so many different variations/setups.
As for the measurements, do you have the ones I asked in the initial post? I plan on purchasing a s197 mustang spindle to confirm the dimensions I got when I mocked the brake setup at home.
Old 10-27-2013, 12:17 AM
For anyone still interested. Now to the next problem, WHEELS!
Old 10-27-2013, 09:58 AM
4mm 4mm is offline
Very nice, would the brackets also work on a 70 Mustang?
Old 10-28-2013, 06:39 PM
If the 70 mustang is using Wilwood Pro-Spindles. If using stock drum brake spindles, Mustang Steve has brackets for them
Old 10-28-2013, 07:52 PM
70 tt rustang's Avatar
70 tt rustang 70 tt rustang is offline
I was also interested in doing the same setup on my 70. Is there a bracket also available for my ssbc setup?
Old 10-29-2013, 06:04 PM
What setup are you referring to? Wilwood pro-spindle with SSBC brakes or 2013 shelby brembos with a stock 70 mustang spindle?
