Old 09-05-2013, 08:03 PM
IndyNova's Avatar
IndyNova IndyNova is offline
Default Gear ratio
Getting ready to order my rear end, and need some help picking a gear out. It'll be a 12 bolt moser rear end. It's going in a 69 nova, 18x8.5 wheels, 6.0 turbo ls motor. 95% will be street driven including long trips, and the other 5 will be auto X and/or road course. Any other info needed, please let me know as this is fairly new to me. Thanks
Old 09-05-2013, 08:21 PM
Flash68's Avatar
Flash68 Flash68 is offline
Trans?
Rear tire height?
Engine rpm?
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 09-06-2013, 01:03 PM
Trans?
Rear tire height?
Engine rpm?
Another important factor to calc ----- where does your CAM begin ---- because CRUISE RPMS should be about 200 rpm under that number. Too low -- and you have sluggish throttle response -- too high (getting into the cam) will kill your gas milage on freeway cruising.
So with the tire DIAMETER --- Final drive gearing of the Tranny --- and RPM's you'd like to cruise at on the freeway using some cam info (65 or 70 or is your state 55? etc) then you have a basis to start to look at gearing.
Once you have that info --- then you have a range on either side to which you can make a judgement --- little "more" gear for better response down low and Auto X etc would be my personal choice...
Kind of a typical street gear might be a overdrive trans with .70 overdriven final --- 25.5" diameter tire -- Cam that comes in around 2400 rpm (so cam might be 2400 to 6300 rpm "type) --- then a 3.70 gear would be about right for some performance and some decent freeway cruising.
But maybe you have a 6 speed and double overdrive trans and it's final gear is .50 ----- then you might be a different gear.
What you will find is that the COMBO --- Trans -- TIRE -- Rear gears is hard to get perfect. And don't go by what someone else says they have. Do a little homework and use some charts to help you make a judgement. It depends on your tranny -- because you might have a real low 1st gear and find that your combo needs to be shifted out of 1st in about 10 feet! Okay if you can live with that -- but some trans have a little taller first gear and then some are different final drive gears... so that info is a must.
My '32 Ford has a very tall rear tire (large diameter) -- a 5 speed trans with .70 final -- and 4:30 gears! That would be crazy in a car with 26" tire diameter - but the larger diameter effectively reduces the gear. When I had 3:90's in it -- it lugged at freeway speeds at 60 mph (ever driven a '32 roadster? they're not a lot of fun at 70!).
I have to shift from 1st quicker than I like --- but everything is a trade off.
Old 09-06-2013, 06:39 PM
IndyNova's Avatar
I've got a bone stock 4l80e trans, with a 275/45/18 rear tire. I haven't ordered a cam yet, but I've been given a few ideas on what I should order.
Old 09-06-2013, 07:31 PM
Sieg's Avatar
Sieg Sieg is offline
Gear ratios of the trans will allow you to factor speed and rpm in each gear.
This is for a 6 spd manual but you can enter your ratios and get the answers:
http://www.tremec.com/calculadora.php
Old 09-06-2013, 09:07 PM
Your tire is 27.74 inch DIAMETER
Your 4L80 is a .75 overdrive (final drive ratio)
If you have a small block -- I'd try to keep the 70 mph cruise at around 2000 to 2200 rpms.... same with a big block
3:70 = 2350rpms
3:89 = 2450rpms
4:11 = 2600rpms
These give you a rough idea of what you're dealing with
Old 09-09-2013, 12:15 PM
gnx7's Avatar
gnx7 gnx7 is offline
I'm building a similar setup. Turbos like engine load.
My tire is a 325/50/15 MT Street Drag Radial (28" tall approx), 3.25 gears, T56 Magnum 6speed. My overdrive is taller than yours so my RPMs will be a bit lower in top gear on the highway. If the cam isn't big it won't surge/buck at cruise.
You don't need a big cam to make power with a turbo. Spend the extra money and get a quality turbo that is properly matched for your engine size and desired power.
You should put in a shift kit which also improves the oiling on the 4L80E. TransGo makes one that most people run on budget setups.
I'm running a baby 225/223 .570" lift cam in my 5.3 setup. On low boost of around 5-7psi it should make 500rwhp. On kill I'm hoping for a few hundred more. My GTS76 billet compressor wheel ball bearing turbo is rated at 1250hp (flywheel). Spool should be good as my engine is around 10:1 compression.
There is a guy (Stock48 on LS1tech) running a 6.0 stock shortblock, 215/215 cam, home ported 317 heads with dual springs, stock truck intake/TB, a quality single turbo and powerglide that went 8.30's@160mph+ at 3,000ft DA in a street car Nova. The car is 3300lbs or so.
Brian Tooley was the chief cylinder head/cam guru at TEA (Total Engine Airflow) and now runs his own company doing valvetrain stuff (springs/cams etc). He can custom grind you a cam for $400. Brian Tooley Racing.
Old 09-17-2013, 12:29 PM
Steve Chryssos's Avatar
3.70 gear is perfect for your Nova. And call us for the converter. You won't be disappointed.
________________
Steve Chryssos
Ridetech.com
