Old 09-07-2013, 06:45 PM
RBuhr69's Avatar
RBuhr69 RBuhr69 is offline
Default Ridetch 4 link
Please understand no complain for Ridetech product and yes it is Saturday so tech support is closed..
Ok, I got all the rear end suspension parts bolted up, got the 4 link bar installed, trailing arms bolted in under car, spring purch bracket for trailing arm bolted up on the leaf spring purch with u-bolts, shocks are bolted up...BUT, the rear and is not centered in the car..Axle tube brackets are equal on the tubes....
How in the world do you center the rear end under the car to make clearance for your tires? Rear end is pushed too far to the left now 3/4 off...
How can I adjust/compensate for this, Got me puzzled.....
Old 09-07-2013, 07:50 PM
Supporting Vendor
You use the upper control arms to move the rear end side-to-side.
Are your upper links currently the same length?
Skunk Werks
Ridetech
www.ridetech.com
Old 09-07-2013, 10:19 PM
Richio1's Avatar
Richio1 Richio1 is offline
Yeah that should do it. When we first installed mine it was off too. Adjusting the length of the upper bars fixed it. Just play with it, adjusting one in and the other out will move it side to side.
I bought one of Prodigy's Moser 4 link rear ends. The pinion angle was off so instead of cutting off and rewelding all the brackets on thear end we installed adjustable rod ends on the lower bars too which gave use even more adjustability.
Jeff
Lateral-g Feature - https://lateral-g.net/forums/showthread.php4?t=44186
Build thread - https://lateral-g.net/forums/show...ght=brownstone
Special thanks to Matt's Classic Bowties along with
Old 09-07-2013, 10:26 PM
If your pinion angle is on the money, adjust one upper only to move the rear end side to side. This will keep your pinion angle in check.
Old 09-08-2013, 07:54 AM
RBuhr69's Avatar
Awesome, thanks for the feedback..going to regroup this morning and see how it turns out....
Old 09-08-2013, 12:19 PM
RBuhr69's Avatar
False alarm..Just got in a hurry yesterday and wasn't checking everything....Got it all lined up this morning and ready to weld tabs..Wheeewww!!!! Had me cared there for a minute..
Old 09-08-2013, 12:26 PM
Bryce Bryce is offline
good news!
