Old 09-08-2013, 05:35 PM
MillerBuilt's Avatar
MillerBuilt MillerBuilt is offline
Default GMR BILLET Front C5/6 Hubs
Up for sale is my personal set of Billet Front C5/6 Hubs. My project has changed course and these are no longer needed.
These are a direct replacement for the stock C5/6 hub units. They retail at over $2020.00+ tax as pictured with Wilwood Rotor Adaptors & Socket Tool (to tighten spindle nut).
This pair can be yours for $1300.00 obo (Mesa,AZ)
***I can accommodate different Caliper/Rotor combinations.
***This setup will add just under +3/16" per side to track width.
Old 09-22-2013, 09:11 AM
Sunday Bump!
Old 10-27-2013, 04:15 PM
Sunday ttt!
Old 11-10-2013, 05:39 PM
To The Top...
Old 01-12-2014, 09:55 PM
Still available?
Old 01-13-2014, 07:38 PM
Actually have two sets available...
Old 01-28-2014, 07:14 PM
Default More Pics!
Below are with WILWOOD Rotor Adapters....
[IMG][/IMG]
Below are with BAER Rotor Adapters....
[IMG][/IMG]
Old 02-23-2014, 07:39 PM
Default C5/6 Billet Hubs
I also have available 2 sets that where used for mock-up ONLY. They are nearly flawless with the exception of a few VERY minor scratches that will not show once mounted. These sets I will sell at a highly discounted rate of $900 per set!!!!!
Old 02-23-2014, 07:42 PM
I think I already know the answer but would they work with stock Z06 rotors
Ryan Austin
Old 02-23-2014, 08:00 PM
Ryan Austin
Although not designed with this rotor application in mind, YES it will work. You would slide the one piece rotor over/onto the Billet Hub just like the OEM, then you would be required to put spacers between caliper mounting lug and the C5/6 Upright caliper mounting point (basically spacing the caliper out over the rotor that would be sitting "outward" approx. 3/16"...... these spacers can be purchased at most any ACE hardware/etc. in the form of a extra thick washer. I use the same type setup when mounting Brake Man Calipers to these hubs....
