Old 09-13-2013, 12:47 AM
BANKO's Avatar
BANKO BANKO is offline
Default 2.5" hole saw recommendation
I need to cut 4 holes in my dash for A/C vents. I'd like recommendations for a quality hole saw (brand / tip coating) that will hold up and create 4 clean holes in 1/8" steel.
Thanks!
Josh
Designing a '65 Chevelle with a StreetFighter theme, inspired by JP's II Much & Ron Schwarz's $5k Mustang
Old 09-13-2013, 05:09 AM
parsonsj parsonsj is offline
The absolute best are Holcutters by Blair Equipment:
http://www.blairequipment.com/holcut...olcutters.html
https://www.youtube.com/watch?v=SyevW...layer_embedded
John Parsons
Old 09-26-2013, 09:14 AM
BANKO's Avatar
These look great and I searched all over the west coast for this size. Unfortunately, none of the local or national distributors had them in stock. Needed to order direct from Michigan. I didn't have the time to wait for them to ship.
FYI, they also are sold under the Hougen brand or
Klein Tools (electrician tools sold via Home Depot) has a similar design.
I was able to find a Lenox Bi-Metal hole saw at Lowe's for under $20 and was impressed with the quality of the holes it cut.
Josh
Old 09-26-2013, 09:25 AM
I get mine from Amazon.com. It usually arrives in a couple of days.
We've considered stocking them, since that's the diameter required to install our bulkhead fuel vents.
John Parsons
Old 09-26-2013, 05:58 PM
Like Mr. Parsons ---- I use a true hole cutter -- I use Hougen Rotabroaches/Holecutters --- they're the same thing basically as what PJ posted just a different brand
Use a hole saw - and you'll just have a nasty mess on your hands.
Old 09-26-2013, 06:08 PM
turnhard turnhard is offline
Electrician knockouts or slugbusters are super clean round cuts. A 2 inch conduit knockout is actually 2 3/8. They last forever when not abused. Kevin
Old 09-27-2013, 12:27 AM
BANKO's Avatar
I was fortunate that in this instance of using a hole saw in thin sheetmetal, I got clean round holes where my vintage air swivel vents needed to go. I was out of time and couldn't find these great tools locally, however they'll be one of the next tool purchases I make.
Josh
