Old 09-17-2013, 01:17 PM
cwylie cwylie is offline
Default Moser center section
Just figured out this is not going to work for my project.
MOSER aluminum thru-bolt center section 3.062 outer bearing part MSR-3062ALU
These are $525 new at summit. I would like $450.
Old 09-17-2013, 01:51 PM
g-machine79's Avatar
g-machine79 g-machine79 is offline
pm sent on p-t.com
Old 09-17-2013, 01:52 PM
Sorry guys its in Austin Texas
Old 09-18-2013, 12:04 AM
NorCal72's Avatar
NorCal72 NorCal72 is offline
Why wouldn't it work? I am running a DSE 9'' with 31 spline moser axles, do you know if this will work for me?
Thanks,
Kevin
72 PT Camaro currently getting Quardralink suspension installed at Meanstreets Performance
29' Ford Roadster Ratrod
57' Big Window Chevy
Old 09-18-2013, 08:12 AM
Im running a speedtech rear setup so the front mount uses the pinion support bolts. The clocking of the Moser bolts are just a little off from the factory ford clocking which caused the front bracket to be a little off and not sit flush on the torque arm. To my knowledge speedtech is the only company that uses that setup so it should work fine with every other setup out there. I was just about to setup the gears when I figured this out. So the 3rd was mocked up for about 5 min before I took it apart.
Old 09-18-2013, 09:06 AM
Sold pending final payment. Thanks everyone.
