Old 09-19-2013, 07:45 PM
rogergrubb rogergrubb is offline
Default 65 Chevelle Rear Disk Conversion Install Question
I'm to the point where I bolt the caliper bracket and backing plate to the axle.
If I bolt the caliper bracket to the axle housing, the bolt heads get I the way of the backing plate.
If I try to bolt the backing plate to the axle, no holes line up.
In the pics, I've temporarily bolted the caliper bracket to the axle housing to illustrate how the backing plate will not sit flat against the caliper bracket.
Please advise this dingleberry how it's done.
"Meow".
