Old 09-22-2013, 01:39 PM
BANKO's Avatar
BANKO BANKO is offline
Default Adapting Ridetech Triples w/ T-bar to Chevelle stock lower a-arm
I'm running into issues not be able to install stock bolts through the lower t-bar into threaded studs on the a-arm. Basically there is no head clearance to get a ratchet and the pocket on the a-arm is too deep for a wrench. I'd like the t-bar supported by the pocket. Thinking of drilling the threaded nuts for a 5/16 bolt and use lock but from the bottom and bolt from the top.
Josh
Designing a '65 Chevelle with a StreetFighter theme, inspired by JP's II Much & Ron Schwarz's $5k Mustang
Old 09-22-2013, 02:12 PM
Vince@Meanstreets's Avatar
That should work fine but watch the length of bolt that you use. 1/8" past the nut is good.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 09-22-2013, 07:17 PM
bret's Avatar
bret bret is offline
Supporting Vendor
Unless you are doing a significant amount of custom fabrication, our shocks will not work with the oem lower control arm. Not enough vertical room on that suspension. How did you end up with that combination?
Bret Voelkel
President
RideTech
Air Ride Technologies, Inc.
Old 09-24-2013, 08:32 AM
BANKO's Avatar
Default Worked like a charm
Drilled out the lower nuts to a 3/8 hole and used 5/16-18 x 1 1/2" bolts and lock nuts.
@ Bret: I got these directly from Ridtech when I reedeemed my
Ridetech Renegade award. No issues with assembly since I mounted them on the top side of the a-arm. I could see that they would not fit if one tried to mount them on the underside similar to the stock shock.
Looking forward to testing and tuning these sweet coilovers!
I can already tell a marked improvement over the stock shocks and 2" dropped springs I just removed.
Josh
