Old 09-30-2013, 06:05 PM
IndyNova's Avatar
IndyNova IndyNova is offline
Default Suspension options.
Hey guys, I've gotten to the point on my car to do the suspension. I was going to order a moser 12 bolt, but I've actually started to think about using my 8.5 10 bolt and adding a new tru track unit with new axles and c-clip eliminators. I am also looking at the ridetech coil over level 2 suspension. Is this a reasonable plan to achieve what I want? It will be mostly street driven, but want to do auto cross also. I'd like to take it down the strip also.
Also, if I go coilovers, does this setup lend itself to adding air ride later if I choose. Any pro's/cons with this setup?
Thanks for any help, it's always appreciated!
Old 09-30-2013, 08:50 PM
Rod P's Avatar
Rod P Rod P is offline
the corporate 10 bolt that GM developed in 1971 is very stout, it uses the same size pinion gear shaft as a 12 bolt and the ring gear is only a little smaller, 8.50 vs 8.875, I often tell people to do just what you're doing, the early 10 bolts (8.2) were terrible they snapped even with a 6cyl cars!! the 8.5 is king
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
Old 09-30-2013, 09:07 PM
Rod P's Avatar
yes that will work great for an all around system, I'm guessing this is for a Nova, the single adjust are a great shock
Rod Prouty
Bangshift Stories
