Old 10-07-2013, 10:32 PM
intocarss's Avatar
Default My new toy
Thank you to the Lat-G members that helped me and are helping me get it
S10 road race truck..Details to come..
Video
FROM THE ADD
NASA/NASCAR PRO TRUCK S-10 PRO TRUCK BODY, BUTLER BUILT RACING SEAT WITH HEAD RESTRAINTS, G-FORCE PRO SERIES 5 POINT HARNESSES, PARKER AIR PUMPER, AUTO METER GAUGES AND TACH WITH SHIFT LIGHT, ON BOARD FIRE SYSTEM, WINK MIRROR, CONVEX RACING MIRROR, NEW OPTIMA BATTERY. CHASSIS AND RUNNING GEAR: ALL TUBE 2000 PRO SERIES PRO TRUCK CHASSIS #097, 9" FORD GRAND NATIONAL REAR-END WITH EATON DETROIT TRUETRAC DIFFERENTIAL, 325:1 GEAR RATIO, 3 BAR REAR SUSPENSION WITH ADJUSTABLE PANHARD BAR, NEW QA1 COIL OVER SHOCKS ON ALL 4 CORNERS,
AFCO UPPER CONTROL ARMS AND STEERING ARMS, 15' X 10' WHEELS WITH GOODYEAR SLICKS, ALL NEW WILWOOD BRAKE PADS WITH NEW PRO LITE ROTORS, FRONT BRAKE FANS, ADJUSTABLE BRAKE PEDAL CONTROL, ADJUSTABLE INLINE BRAKE CONTROL, 4 SPEED JERICO TRANSMISSION WITH 7.25 TILTON 3 DICS CLUTCH AND TILTON NASCAR FLYWHEEL. ENGINE & COOLING: 500+ HP 385 STROKER WITH 11:1 COMPRESSION, EAGLE 4340 FORGED STEEL INTERNALLY BALANCED CRANK 3.75 STROKE, 6" EAGLE BALANCED H-BEAM RODS, .040 OVER SRP PISTONS, BILLET TIMING GEAR SET, COMP CAMS THUMPER 299T7 HYDRAULIC ROLLER CAMSHAFT WITH ROLLER ROCKERS & ROLLER LIFTERS,
IK200 BRODIX ALUMINUM HEADS, EDELBROCK RPM AIR GAP INTAKE, 750CFM MIGHTY DEMON CARB, MOROSO HIGH VOLUME OIL PUMP, HIGH VOLUME WATER PUMP, PRO COMP HEI DISTRIBUTER, MSD SOFT TOUCH REV CONTROL, PRO COMP ALUMINUM VALVE COVERS, PRO COMP HIGH VOLUME FUEL PUMP, CHAMP STYLE TRAP DOOR ROAD RACE OIL PAN, MILODIN WINDAGE TRAY AND CRANK SCRAPERS, DUAL VALVE COVER VENT CANS, EDELBROCK AIR/FUEL RATIO MONITOR, MOROSO ACCUSUMP SYSTEM, REAR MOUNTED FLUIDYNE ALUMINUM RADIATOR WITH DUAL FANS, 15 GAL FUEL SAFE FUEL CELL
Old 10-07-2013, 10:47 PM
intocarss's Avatar
Haven't seen it in person yet
Old 10-07-2013, 10:49 PM
intocarss's Avatar
and more
Old 10-07-2013, 10:50 PM
FETorino's Avatar
FETorino FETorino is offline
JerDog you are the smartest one of all of us. That thing will be a blast and it's ready to go and I bet the price was right.
Congratulations on the purchase.
Rob in SoCal
Old 10-07-2013, 10:56 PM
intocarss's Avatar
Don't know if i'm the smartest...The whole thing became a deal i couldn't pass up. Yup, it'll be "more fun then a barrel of monkeys" And I think it's just small enough to pass you without putting 2 in the dirt
Old 10-07-2013, 11:00 PM
Vince@Meanstreets's Avatar
....and away we go!!!
Tell me your gonna rebody it make it abit street able
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 10-07-2013, 11:06 PM
intocarss's Avatar
I like trucks and the thought has crossed my mind a few times... It'll stay just the way it is for quite a while. Plus it may be a bitch in LA traffic LOLOL
Old 10-07-2013, 11:15 PM
Ron in SoCal's Avatar
Congrats Doggie. Can't wait to see it!
Ron in SoCal
69 Camaro in progress
Yeah I hear ya, get a paddock at Adams and call it a day!!!! Either way it's gonna be a blast for you.
Dealer for
NEVER FORGET -11
Old 10-08-2013, 05:09 AM
Track Junky's Avatar
Unfrickinbelievable . What happened drag racer.........change of heart?
Regardless......great move. Your way ahead of the game now. Have some fun with that bad boy!!
Gaetano Cosentino
