Old 10-20-2013, 12:09 PM
Rileys68Camaro Rileys68Camaro is offline
Default Tell me about the 5.3 for a 68 Camaro.
I'm researching this pretty hard as I really want a FI engine, but can't do an LSx, and I want something newer and better than an LT1. I have a GMPP 300hp crate but I need a carb and all the fuel system and such, minus tank.
If I can get a good pull out with transmission and wiring I think I'll be money ahead. However, I don't see much about the 5.3 as it's usually a truck engine and not a high power one at that, compared to an LS.
Old 10-20-2013, 12:45 PM
Bsinclair Bsinclair is offline
gm performance part number 19165628 is rated at 327hp and 347ft lbs and can be purchased brand new for around $3300. this is a cast iron block.
finding a pull out shouldn't be that hard as there is a ton of them out there. be careful as the blocks are stamped 4.8/5.3 so make sure you can verify its a 5.3
Old 10-20-2013, 12:53 PM
I've looked at those, and for the price of the engine, I can have my SBC all set up with a new transmission ready to go.
So, I need to be about $1500-1800 complete with transmission to make the switch at this point.
Old 10-20-2013, 02:01 PM
mustangracer11 mustangracer11 is offline
You should be able to find a used 5.3 cheap. My buddy bought one with 60k miles for $350. You can put some 243 heads on a good cam and intake and it will make decent power.
Old 10-20-2013, 02:42 PM
$350 complete? Good deal anyway.
Where I'm at now, is I have a brand new GMPP 300hp 350, but it's been sitting for 10 years in the car. Only ran for a few minutes. However, I need all the brackets and such to mount the A/C and P/S especially as well as a new carb and a transmission.
So, a good take out 5.3 and transmission seems like a better deal at this point, depending of how much work it would take to get the front drive stuff to fit and wire it in. I have a flat hood and stock sub-frame set up with a custom cross member for a 700R4 or 4l60 transmission.
Old 10-20-2013, 06:24 PM
It was complete minus the drive accorries I'm sure it will cost more to do the 5.3 swap than it would to just buy a fuel injection set up for what you already have.
Old 10-31-2013, 04:12 AM
67Rally's Avatar
67Rally 67Rally is offline
Some of the 5.3's already come with the 799 heads. 799 heads are the same as 243 heads, just made in a different plant.
If you get the 799/243's I'd do a valve job, healthy cam, swap an LS6 intake on there and get a good tune. You'd have a fun little motor.
I did a 6.0l LQ9 in my '67 and it's crazy fun. 458rwhp and no carb to fiddle with!
Old 10-31-2013, 08:10 AM
gnx7's Avatar
gnx7 gnx7 is offline
If you find an L33 engine that is an alum 5.3 block; however they have DOD/VVT. If you convert it back over to a standard style cam you need the following: front LS2/LS3 cover and valley cover, LS7 lifters, new cam, new pushrods, new timing set which will put you way over budget. The 85lb weight saving is nice though. The heads don't matter a ton once you swap in a cam. Maybe 10-20hp difference in head castings. You can also mill the heads to gain more compression and get some free power.
I paid $650 for an L33 shortblock.... then added ported 5.3 heads, LS9 gaskets, ARP head studs, ARP rod bolts, LS6 intake, ported TB, 120# injectors, used cam, LS7 lifters, front cover, valley cover, timing set and I was into it for over $3000 doing all the work myself.
The only way you are going to do it for $1500-1800 on the engine and trans is to buy a complete totalled vehicle and part it out making some money back or you better have one hell of a hookup. You will be hard pressed to do it otherwise. The fuel system alone doing it cheaply (weld in a sump, the lines, pump, regulator/fittings) will be a few hundred easily. Then you need a tune as well and redo/relabel the wiring harness. A 5.3 without at least a cam upgrade is going to be a dog. That would require head gaskets and some new bolts and most likely deck the heads for a fresh mating surface. Just trying to be realistic.
Old 10-31-2013, 10:06 AM
gray776's Avatar
gray776 gray776 is offline
5.3 Complete $500
Used cam LS1tech.com $200
Springs/PR $300
LS1 intake/TB/injectors $200
Fbody Pan $200
Harness and Comp $500
Walbro pump $100
Corvette Reg $50
Fuel lines/fittings $100
Total: $2150 give or take a few hundred.
You can bolt this to whatever tranny you currently have and that would get you 350hp all day long, and will run SO much stronger than your 300hp crate as well as prolly get 18-20mpgs. Just ask anyone who has swapped a LS engine. A 350hp LS is a large difference over even a 350hp SBC.
Old 10-31-2013, 09:13 PM
Che70velle's Avatar
The L33 is a great engine, however it does not have VVT, or DOD. It is a mirror image of the LM7, with the exception of flat top pistons for a compression bump, and a unique to the L33 camshaft that gave the L33 the name 5.3 H.O. Obviously, they are an all aluminum engine, vs. the LM7 being iron block, with aluminum heads.
The heads on the L33 are excellent, and are basically 243 castings with different valves.
Available only in extended cab 4WD trucks in 2005-2006, these guys were a gen3 engine, and are getting harder to find.
I swapped one last year into a suburban, and really picked up the vehicles power and mileage.
Thanks Dad!!
