Old 10-22-2013, 06:49 AM
GT500KR_Vert's Avatar
GT500KR_Vert GT500KR_Vert is offline
Default 68 GT500KR Vert
Project Overview
The Car:
Was working on another Mustang for 3 years - the shop I was working with turned the car into a abstract work of art. So with all the part I had I started over by picking up this car about 7 years ago from a horse barn outside Pittsburg, PA. Got it home, ended up being pretty much rusted everywhere. Hasn't been on the road since 1985. Had no motor or anything else, pretty much a shell.
The Work:
During the 10 years I've been working on it, I've had 3 different shops try to rip me off, take advantage of situations, deliver incredibly poor work, and take me to court because they wanted to get paid for work they didn't do and had closed the shop. Luckily, I haven't lost that much money, but it took a while to save back up again and find the right shop who really cares about their work, customer, and perfection. They finally started on my car last week after years in storage hell and battles with other shops. They just started redoing the rear end work to get all the panels and gaps aligned and will be working their way forward in the next few weeks.
Engine:
Never used 1970 429 SCJ engine with 4 bolt main and original oil cooler (The complete short block is original - Sat in my Dad's shop since it was new.
* Only replaced in the lower half were the bearings.
* Stock heads - D0OE-R Heads (Hardened seats, SS Valves, Bronze Valve Guides)
* Compcam Springs & Roller Rockers
* Compcam Roller Cam
* Compcam Roller Lifters
* APR Head Studs & Bolts
* Holley finned aluminum valve covers powered coated silver
* Edlebrock RPM Air-Gap manifold
* Edlebrock Water Pump - powder coated clear
* Concept One Serpentine Pulley Kit - Black
* ATI Balancer
* Canton Oil Pan
* Powermaster mini starter
* Ron Davis Crossflow Radiator & SPAL Fan system
* ICE Ignition System, Booster, & Distributor
* Classic Auto Air A/C System
* 565HP / 595TQ under 5,000RPM
Fuel System:
* Pro System 950 Carb
* Holley HP In-Line Billet Fuel Pump
* Fuel Safe Pro Cell 22 Gallon Tank
* Earl's Fittings and Lines
Electrical:
* Painless Wiring Harness - 1968 Mustang
* New accessories wiring harnesses (Convert, Fog Lights, Etc)
* Battery In Trunk
Exhaust:
* FPA Custom Ceramic Coated Headers
* Magnaflow 3" stainless steel exhaust system
Drivetrain:
* Performance Automatic C6 with Custom Torque Conv
* Steel driveshaft
* Strange 9" rear w/ 31 spline axles, Positrac 3.50
Chassis:
* Rod & Custom Motorsports Mustang II Front End with coil-overs modified for better steering and handling.
* Rod & Custom Motorsports Rear Coil-over system
* Forged 2" drop spindles
* Flaming River Steering Column & PowerRack.
* TCP Subframe Connectors & Cross Brace + Additional Custom Support.
* All new frame rails, torque boxes, inner rockers, and floor - all seam welded for strength.
Brakes:
* 4 X 12" Aerospace Components Pro-Street Disc Brakes - D/S/P & Billet Aluminum 4 Piston Calipers
* JMC dual master cylinder
* Hydratech Brake System
* SS brake lines
Body:
* Stangaholics 1968 Shelby Fiberglass kit
* All body panels replaced where needed[Ford tooling panels when available](rear qtrs, front fenders, complete floor pan, inner rockers, toe pans, seat riser, radiator support, rear valance, complete trunk, transition pan, taillight panel, and wheel housings)
* Engine bay custom constructed for MII front-end
* Red / White Paint Scheme
* Black Chassis paint in engine bay and underbody.
* Haartz Stayfast Black cloth convertible top.
Interior:
* Dakota Digital Dash with trans gear indicator and accessory gauges for the Shelby center console.
* Black Pro-Car Rally seats & matching rear upholstery.
* Lecarra Steering Moto-Lita wheel
* Saleen Light Bar
* Lokar gas pedal assembly, brake pedal cover, & foot rest pedal
* Lokar Shifter
* Electric Life Power Windows
Wheels:
* Shelby CS67 Wheel In Anthracite (18x8.5 front / 18x9.5 back)
* BFGoodrich g-Force T/A KDW (235/40ZR18 front / back 275/40/18)
Other:
* All brackets and accessories will be powder coated.
1968 Shelby GT500KR Vert
CarDomain: http://www.cardomain.com/ride/2576876
