Old 10-23-2013, 12:59 PM
Ellis Ellis is offline
Default Gear ratio/700r tranny info.
Would like to thank CAMCOJB for his imput on my request for info I posted on running 3:73 gears with 700r trans for street and criusing in my 69 Chevelle, appreciate your help. Ellis
Old 10-23-2013, 09:00 PM
That's the perfect gear tranny combo unless you're running some goofy tire size....
Old 10-24-2013, 06:53 AM
Steve Chryssos's Avatar
Yup. With a 25.5" to 26" tire and a 700R4 (or 4L60E, 4L80E) 3.73 is perfect. It keeps the engine in the powerband at cruise speeds. Some folks out-trick themselves by choosing too high a gear (too low numerical) only to find that drivability and throttle response both suffer. Go with a 3.73 gear.
EDIT: And get the converter right, also. Call us for help.
________________
Steve Chryssos
Ridetech.com
Old 11-19-2013, 09:36 PM
Chicken Louie's Avatar
Chicken Louie Chicken Louie is offline
Default Gear of Confusion
Would 3.50 be considered to high of a gear?
I am looking at the rpm calculator and leaning toward the 3.5x than the 3.7x
The car is LS equipped with a 4l70e and the rear tire is 295/35/18.
Suggestions?
Old 11-20-2013, 10:04 AM
A 4L70E offers more flexibility as it's possible to use software to raise 3-4 shift points and lock up speeds. While I still favor 3.73's, for the 4L70E, a 3.50 works well as long as the cam is not too crazy.
It's all about keeping the engine in its power band when in overdrive.
________________
Steve Chryssos
Ridetech.com
