Old 10-24-2013, 04:49 AM
paulk68 paulk68 is offline
Default 10K for a turn Key EFI LS
if you had 10K to get a complete running LS EFI motor what direction would you go? obviously i would like the most HP /TQ I can get for that price.
Old 10-24-2013, 04:53 AM
makoshark makoshark is offline
The GM crate LS3 offered by Jegs for around $6500 shipped is about the best deal out there right now.
With that said, it would be tough to do all the electronics, fuel system, swap parts and price of the motor for $10,000
Old 10-24-2013, 05:03 AM
Yeah that is one of my options also looking at the texas speed and performance 370 cid 520 HP LQ9 for 10,799. comes with everything needed to drop in. I know the entire swap will be more than 10K but strictly looking at just turn key motors.
Old 10-24-2013, 05:13 AM
If I were planning to boost the motor, I'd do an iron block. But if I planned to keep it N/A, then I'd do an aluminum block to save a bit of weight. That GM crate from Jegs is a tough deal to pass up if you are in the market for such.
What is your criteria, aka. goals for the power plant?
Old 10-24-2013, 05:21 AM
I am basically looking for a good weekend/couple times a week driver. I do like the idea of being able to add a supercharger sometime down the road if i was not happy with the power i had but like you said that jegs add just keeps calling me LOL
Old 10-24-2013, 05:24 AM
You can boost the LS3, no problem. I just feel the iron blocks are a little better for longevity and running a lot of boost than their equivalent aluminum blocks.
That Jegs sale is calling my name too! And I'm not even in the market for a new motor
Old 10-24-2013, 05:38 AM
Yeah that make sense, it is so hard to not get caught up in the "just a little bit more $ will get you this" LOL
Old 10-24-2013, 08:02 AM
tubbed69's Avatar
tubbed69 tubbed69 is offline
Shaun Carter at SMC Performance is very good on prices for complete setups ready to go,I bought a new LS3 with Comp Cam,Patriot Gold valve spring,pushrods complete from intake to oil pan with LS7 clutch,pressure plate and flywheel,gm ecm,complete warness also wired for dual fans,throttle pedal and 02 senors for just a little over 10k,Shaun is very good guy and very smart on ls motors.
Old 10-24-2013, 02:20 PM
tazzz2_ca's Avatar
tazzz2_ca tazzz2_ca is offline
The guys over at West Bend Dyno may have something that'll work for you... I'd call Brad 1-262-692-9035, tell him what you want to accomplish and the budget you have and see what he suggests.... Some times a fresh perspective can shed some light on options we don't necessarily think about... Also they may have something that they can freshen up that will allow you to stretch your dollar,,, worth a call at the very least....
-73TA WarPath (Summer 2016)
-72RS Il Vagabondo
-70 Blue Formula "Project Cochise"
-70 Z shell
-70 Formula shell
-70 Formula roller
-68 Eldorado
-67 Coupe De Ville convertible
Old 10-24-2013, 08:42 PM
Che70velle's Avatar
I wouldn't be afraid to boost an aluminum LS. Please guys, don't believe everything you hear. Look at facts. Check out Ohio Boys racing. They are in the 7's at 200ish with an aluminum block ls2. There are many others making 1000+ with turbos on an aluminum block. Just sayin'...
Thanks Dad!!
