Old 10-25-2013, 04:36 PM
72Z/28's Avatar
72Z/28 72Z/28 is offline
Default Mcleod Bellhousing for TKO600/LS6
Hello Guys
Just wondering if anybody knows the part no for the Mcleod bellhousing for TKO600 to be mated to LS6 with LS7 clutch.
Your input will be highly appreciated.
72 Camaro RS:SOLD
68 Camaro:
LS6 Engine,Tremec TKO 600,5 Speed
Complete Speedtech Subframe Kit,Speedtech Torque Arm, 9" Rearend from Strange, Wilwood Brakes, Minitubbed, Hotchkis Subframe Connectors, FIKSE FM5s
Old 10-26-2013, 11:56 AM
72Z/28's Avatar
It seems like nobody is using Mcleod Bellhousing with TKO600/LS Block..So what bellhousing are you guys using when mating Tremec TKO600 to LS1/LS6 Block?
I have heard that some bellhousings do not have the bolt hole on the 12 o'clock position of the LS block..
72 Camaro RS:SOLD
68 Camaro:
Old 10-26-2013, 01:07 PM
Vortech404 Vortech404 is offline
I thinks most people are running the Quick Time bellhousings.
Take a look at those.
John
Old 10-26-2013, 01:24 PM
72Z/28's Avatar
John
I have looked at the Quicktime ones, but if i am not mistaken threir bellhousings are made for 10.5" clutch disc
I have heard that Mcleod bellhousings specs are accurately made so their runout is always within .005" without offset dowel pins
72 Camaro RS:SOLD
68 Camaro:
Old 10-26-2013, 07:14 PM
72 Z/28
It states 11" clutch here.
http://lakewoodindustries.com/ls1-to-ls1-t56-chevy.html
Ask the guy's at ls1tech.com also.
John
Old 10-27-2013, 02:19 PM
72Z/28's Avatar
Thanks John. I have checked the website, and the Quicktime bellhouging part no for my application is RM-6036
72 Camaro RS:SOLD
68 Camaro:
