Old 10-27-2013, 10:34 AM
marks914's Avatar
marks914 marks914 is offline
Regular User
Default New Performance II gauge sets from NVU
New Performance II sets from NVU
With the popularity of our Performance II and Cal-Custom Performance lines We thought I would only be appropriate to expand the performance series to our backlit stepper motor sets.
This graphic design is so new we don’t even have part numbers released for them yet. We started with the core parts from the 69 and redline series, which all have LED backlighting, full sweep stepper motors and warning outputs on the 2-1/16” gauges. Then the performance graphics were applied and then added blue backlighting with a red pointer for more of a custom look. The performance graphics are bold without looking race, very appropriate and classy without the in-your-face look of other styles on the market.
Once the dials are on, the gauges are capped off with actual glass lenses and our exclusive smoked-chrome titanium bezels.
Each kit includes:
3-3/8” Speedometer: Electronic 160 MPH fully programmable
3-3/8” Tachometer: Electronic 0-10,000 RPM operates on 112 cylinders
2-1/16” Fuel gauge: Programmable for 0-90, 73-10, 10-180, 0-30, 240-33
2-1/16”Temperature: electronic with sender
2-1/16”Pressure: electronic with sender
Minor gauges also have peak high and low recall with programmable warning outputs to let you know if there is a problem under the hood; trigger a lamp or combine with an NVU indicator panel for a complete dash setup.
Also included in kit:
Wiring harnesses for minor gauges
Bushing kit
Backclamps and mounting hardware
Detailed instructions
Speedometer operates on most any speed sender including GPS senders (not included). Tachometer operates on most ignition systems, CDI boxes, HEI and PCM outputs
Need more functions or additional gauges to match? New Vintage is also the leader in custom gauges and gauge sets. Need a custom range or special graphics? No problem. NVU can build virtually any gauge, any size any function.
All NVU products are made in Detroit and include a 5-year warranty and great tech support.
We are offering these kits for a limited time at $489.95. This price is only good in our web store for a week or two until part numbers are released to our distributors. We can only offer this special deal as an introductory offer until part numbers are published. The link is here:
http://stores.newvintageusa-store.co...Categories.bok
As of this moment the gauges are available in 6 gauge kits, we can custom build other functions as needed: Vac/Boost, Oil Temp, EGT, etc.
And as always if you don’t see what you need or have something special in mind let us know we can make virtually ANYTHING you want.
perf2night
perf2blk
perf2silver
perf2white
www.newvintageusa.com
